Home > Td5 > td5 ecu
fermin123
2000 Defender 130 Td5 HCPU Alpine White
td5 ecu
hi,
i have 2 defenders one with abs-tc and other without same year on is 110 and other 130
if i put the abs ecu in the non abs defender the throttle doesnt works the throttle sensors are different
or is tps bad?
is there a abs ecu non abs ecu??
Post #73938 3rd Jun 2011 3:25am
I thought that the traction control system can regulate the throttle as well as activate the brakes, so the result you get is to my mind not unexpected. The TPS is probably the same, but the ECU I would think is undoubtedly different and incompatible.
If it is not a daft question, why are you trying to swap the ECUs over? Seems a very odd thing to do!
Post #73952 3rd Jun 2011 7:55am
Martin
Site Admin
What years are the 110 and 130?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #73963 3rd Jun 2011 8:55am
fermin123
tps connectors are differnt 110 abs is 2001 and defender 130 is 2000 non abs
Post #73996 3rd Jun 2011 12:49pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I would say one of them has a 2 track accelerator pedal and the other has a 3 track pedal. The 2 track can be used with all models but the 3 track only with the later nnn ecu. You need to tell the ecu which pedal there is fitted or it wont work at all, to do this you need a nanocom or something similar.
Pete.
Post #74013 3rd Jun 2011 3:08pm
Martin
Site Admin
Change the throttle pedal over as well as the ECU?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #74014 3rd Jun 2011 3:33pm
td5 commercial
2014 Defender 90 Puma 2.2 HT Baltic Blue
when you swap the ecu's you need to enter the 5 injector codes and also preform the "security learn" procedure, i would have thought they are both on two track because4 of the year of them.
Post #74073 3rd Jun 2011 8:50pm
Martin
Site Admin
If the engine runs, then the security is OK.
Injector codes are correction factors for optimal running, as long as there are some injector codes programmed into the ECU then it will run.
I know this as I swapped engines in my 90, and it ran and drove fine with the old injector codes programmed in.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #74080 3rd Jun 2011 9:04pm
fermin123
hi i am getting crazy
the thottle pedals look the same the only difference is that the abs has 7 wires in different position and the non abs has 6 wires i bopught this defender non abs without starting because the engine was bad but i want to buy theecu buty iam not sure if this part umber is for non abs msb101171
Post #74211 4th Jun 2011 1:35pm
Martin
Site Admin
The ECU is the same for ABS or not.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #74213 4th Jun 2011 2:12pm
