Home > Puma (Tdci) > Leaking water pump..gasket I think
mfjeep
United Kingdom 2009 Defender 110 Puma 2.4 CSW Epsom Green
Hi all, little bit of help here would be appreciated. (Puma 2.4 tdci 2010)
So my water pump started dropping coolant, I didn’t notice until she went into limp mode.
Whipped off the pump, looked like the fibre gasket (yes it was a fibre one) had bust at the bottom.
So went to Eurocsr parts today and got a replacement one (metal this time). Fitted it, filled system with water to test....leaking!..took it back off checked it over for damage, refitted it..., leaking! Went to Halfords, bought some locktite gasket silicone...fitted it...yup...leaking. Thought maybe I haven’t used enough sealer so tried again with more sealant.....stilll f...!! Leaking!!
Anyone got any ideas? it’s a straight forward job..I fitted the pump myself a couple of years back...I’m totally befuddled.
Post #783867 29th Jul 2019 7:57pm
When mine leaked it was the pump shaft seal that had failed, resulting in coolant leaking from a drain hole below the pump. With the pump on the engine it was impossible to see where the leak was coming from.
Post #783874 29th Jul 2019 8:39pm
Minch90
Same here pump shaft failure 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #783876 29th Jul 2019 8:43pm
mfjeep
Thanks..that’s exactly right, impossible to see where it’s coming from..thanks so much ..I think that explains it Thumbs Up
Post #783885 29th Jul 2019 9:13pm
MK
Bow down Ford Puma 110" SW
Post #783996 30th Jul 2019 10:45am
Buy a Borg & Beck one for a 2.4. £85 and don’t go to that LR ridiculous price. I did and has been faultless ever since I fitted it a few years ago. In fact running temp is now a touch lower as well, although that may be combined with new coolant.
I recon it had some rubbish concentrate and water mix in before, I used pre mixed and that seemed a lot better. Then you know at least it’s a distilled water and coolant mix without and mineral deposits in it etc and mixed to the exact spec. Yes, costs a little more but saves the work.
Although everyone has their preferences. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #784000 30th Jul 2019 10:59am
Forgot to add. LR tried to charge me £580 to replace it plus a pressure test that was £120! Arrow Neutral WeWillWin🇬🇧🇺🇸
Post #784001 30th Jul 2019 11:00am
BrickBox
Just bumping this thread.
Is it worth buying the water pump and vac pump complete and change them together, for peace of mind?
https://www.ebay.co.uk/itm/253485212912?mk...media=COPY 2008 2.4 110 Utility Station Wagon XS.
Post #984578 6th Mar 2023 1:17pm
BrickBox
Anyone able to shed some advice on the above , please? 2008 2.4 110 Utility Station Wagon XS.
Post #984601 6th Mar 2023 5:03pm
Vac pump should be fine just replace gaskets.
With the waterpump, the whole unit inc manifold I would advise. WeWillWin🇬🇧🇺🇸
Post #984614 6th Mar 2023 6:44pm
BrickBox
Brilliant - thank you
I already have the Borg & Beck complete water pump unit. I wasn’t sure whether I should send it back and buy the one from the link above as it comes with the vac pump. There’s nothing wrong with my vac pump - I was just assuming preventative Maintenance. 2008 2.4 110 Utility Station Wagon XS.
Post #984623 6th Mar 2023 7:36pm
Just lift the vac pump up and away and tie just out the way after removing the three bolts.
That’s all that’s needed with that, don’t undo the hose and coupling attached to it, it’s more trouble than it’s worth so I have heard so I’m glad that I never did.
If you can get away without dismantling anything whilst doing a job then that’s ideal, you never know what might break otherwise. And then get one job end up turning into three.
Some tissue paper such and blue workshop paper or kitchen roll is a good idea to clean up any minor spills of fluids, otherwise a little can get everywhere.
Post #984627 6th Mar 2023 8:19pm
BrickBox
Fantastic advice, thank you! Bow down 2008 2.4 110 Utility Station Wagon XS.
Post #984630 6th Mar 2023 8:31pm
