Home > For Sale & Wanted > [Wanted] Defender TD5 110 front diff (sorted thanks)
kevinf
Hi all
I'm looking for a good condition P38 2 pin differential !
For the front of my 110 TD5, after mine tried to eat its own crown wheel bolts
Cheers kevin
Post #781505 14th Jul 2019 9:13pm
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
Unless I'm mistaken, the front diff is a standard 24 spline, 3.54 ratio Rover type diff. Only the rear axle on a 110 has a P38/Wolf differential (unless it's an earlier Salisbury axle of course)
Hope that makes your search easier.
Post #781523 15th Jul 2019 6:43am
^^ Correct. A P38 short nose diff won't fit the front axle of either a Puma or a TD5.
You need a Rover pattern (long nose) diff. TD5 and Puma are interchangeable in the front across all wheelbases (90, 100, and 130), however you may want to consider fitting a four-gear diff as used (allegedly) on late Puma 110 and 130 models (and possibly 90s) since the earlier two-gear diff is of marginal strength.
You don't seem to hear of TD5s destroying two-gear diffs, but Pumas do regularly and the four gear diff is the only sensible option for these.
Post #781536 15th Jul 2019 8:08am
kevinf
Cheers thanks for info
It might make it easier to find a diff now
Post #781616 15th Jul 2019 7:50pm
Merlin
Are these a direct fit? Anything I should know before ordering? Peter
Post #803094 21st Nov 2019 5:53pm
