Home > Maintenance & Modifications > removable winch setup
Page 2 of 2 <12
Pilgrimmick
No, that is it, the support brackets will hold the winch in place while you pick up the pins, so no fumbling around to reach them.
The brackets for the tow bar are deeper, just so that the box section is big/strong enough to cope with trailer.
My winch is hydraulic, so on quick couplings, if electric just use Anderson connectors.
So if electric, to move from back to front, (for example)
Disconnect Anderson connector.
Remove 2x pins, place in winch tray.
Pick up winch tray, notice handles incorporated into body and take to front of vehicle.
Slot into position.
Fit 2xpins and clips
Connect Anderson connector.
Good to go, 2 min max!
If setting it up like this, do NOT make the tolerances too tight, the idea is that is is secure but can cope with mud on fittings and pins, it is made to work, not to look pretty. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #779510 29th Jun 2019 11:00am
Pilgrimmick
Although I think it looks OK!😇 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #779512 29th Jun 2019 11:02am
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
nice indeed, simplified setup
Post #779515 29th Jun 2019 11:06am
Page 2 of 2 <12
