![]() | Home > Tdi > Millie's Problem |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
Exactly that ^^^
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
Whatever it is, I'm positive it has nothing to do with me driving it!
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 ![]() ![]() ![]() |
Thats like a clogged filter. . the solenoid kills the motor , |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
someone mentioned there's a gauze on the bosch ve pump and this can get clogged, but not many people know about it.
I think he said it's on the inlet or something, might be worth having a look. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
Hope you get it sorted soon Clayton. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10969 ![]() ![]() |
UPDATE
With all of your help i have sorted this problem out now and Millie has not coughed since ( touching the table and saying, touch wood ![]() On the Friday just gone after work i went around to my store, i had to doing a little job there first ![]() ![]() This is a pic of what i am trying to explain as i didn't take any pic's ......... ![]() Click image to enlarge So i cleaned up the male spade end and what goes on top of the stop solenoid and then cleaned up the female end and crimped it up a bit and i have a good fit now, so once altogether, i have cable tied the wire to the throttle cable bracket so it does not come apart hopefully again ![]() Does anyone else have this set up as i thought the wire would go straight on to the stop solenoid ![]() I'm thinking now that Millie is going much better now as this could of been going on, but not coughing and causing the stop solenoid plunger to restrict the flow of diesel to the injector pump ![]() Thank you again to you all ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Result, well done.
![]() Was the nut loose or was it just the female connector to male? Is there a reason why it has that set up perhaps to stand-off? Or otherwise why wouldn't a ring terminal direct to the solenoid threadeded post be much better removing a failiure point. Maybe they're isn't room perhaps. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
It was the female connector to the male spade that was loose
![]() The only reason i can see for this method is that when the injector pump is taken out, you just have to pull the live wire from the male spade, no fiddling with the small nut ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Mariner Member Since: 03 Oct 2017 Location: Arklow Posts: 127 ![]() ![]() |
Good job
![]() Sometimes it's the simple things that catch you out. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5274 ![]() ![]() |
I had the good old spade connect problem too, on my rover metro. a good nip with the pair of pliers and all was well again. ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
