Home > Technical > LT230 with Ashcrooft ATB - looking for opinions |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
pardon my ignorance, but that do the 1.2/1.3/1.4 ratio refer to?
I have a BAS remap & Alive intercooler and sometimes I find myself wanting a 7th gear - would a lower ratio then be a recommended mod? Does this mod change the Low Range or only the High? thanks -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
24th Jun 2019 7:51am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
I'm not expert so wait to be corrected but this ratio is the transfer box gearing. Early Defenders run 1.4 but the Pumas already run 1.2. The ratio is both low and high.
I've not heard of an overdrive for a Puma? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
24th Jun 2019 12:53pm |
That particular ratio is high range only. These sorts of mods typically leave the low range ratio alone. Darren
24th Jun 2019 12:58pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
Similarly I am no expert but believe the ratio applies only to high range - see here https://www.ashcroft-transmissions.co.uk/lt230-ratio-changes.html
The ratios are the same principle as a gearbox. Change gear to suit engine revs, torque and road speed The way I understand it, think about the drive coming from the gearbox, into and through the transfer box and then out the other end to the propshaft(s) So, if the transfer box ratio was 1.0 and the gearbox is outputting 1000rpm then the propshaft(s) also spin at 1000rpm If the ratio is 1.2 then the props spin at 1200rpm, If the ratio is 1.4 then the props spin at 1400rpm So the lower the ratio then the easier(faster?) acceleration in lower gears, but will top out at lower speed/require higher revs to achieve the same speed > 110 XS Double Cab Last edited by hank on 25th Jun 2019 5:19am. Edited 1 time in total |
24th Jun 2019 1:02pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 |
@hank
That is incorrect as I understand it. If the output from the gearbox is 1000 rpm, the output of the transfer box would be as follows: 1.2 = 833 rpm 1.3 = 769 rpm 1.4 = 714 rpm I find that I can actually accelerate as fast with 1.3 as I could with 1.4, I put it down to the engine spending more time in the sweet spot of the power curve due to the way a turbo diesel works. |
24th Jun 2019 10:29pm |
Ahhh thanks mrd1990, so it works the opposite way round! > 110 XS Double Cab
25th Jun 2019 5:19am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17540 |
Correct, the transfer box is a reduction gearbox, not an overdrive. The output is turning slower than the the input.
25th Jun 2019 6:52am |
So would a Puma benefit from going from 1.2 to 1.4? --
25th Jun 2019 6:57am |
Not unless you've put huge tyres on it. Otherwise, it'd be painfully slow and 1st would be redundant. Darren
25th Jun 2019 7:07am |
Ah, so with the Puma, we're looking to go down, as in a 1.1 box? --
25th Jun 2019 7:08am |
If you want to raise the gearing then yes. Darren
25th Jun 2019 7:12am |
Some interesting info on the ratio options https://forums.lr4x4.com/topic/104279-new-lt230-ratios/ > 110 XS Double Cab
25th Jun 2019 8:58am |
I take it no one has done the 1.1 mod yet then? --
26th Jun 2019 7:31am |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 |
Hi,
yes, many customers have, works very well with a tuned TDCi, Dave |
26th Jun 2019 12:07pm |
