Home > Technical > LT230 with Ashcrooft ATB - looking for opinions
Page 2 of 4 <1234>
Naks
pardon my ignorance, but that do the 1.2/1.3/1.4 ratio refer to?
I have a BAS remap & Alive intercooler and sometimes I find myself wanting a 7th gear - would a lower ratio then be a recommended mod?
Does this mod change the Low Range or only the High?
thanks --
Post #778722 24th Jun 2019 7:51am
JOW240725
I'm not expert so wait to be corrected but this ratio is the transfer box gearing. Early Defenders run 1.4 but the Pumas already run 1.2. The ratio is both low and high.
I've not heard of an overdrive for a Puma? James
Instagram @suffolk_rovers
Post #778769 24th Jun 2019 12:53pm
That particular ratio is high range only. These sorts of mods typically leave the low range ratio alone. Darren
Post #778771 24th Jun 2019 12:58pm
hank
Similarly I am no expert but believe the ratio applies only to high range - see here https://www.ashcroft-transmissions.co.uk/lt230-ratio-changes.html
The ratios are the same principle as a gearbox. Change gear to suit engine revs, torque and road speed
The way I understand it, think about the drive coming from the gearbox, into and through the transfer box and then out the other end to the propshaft(s)
So, if the transfer box ratio was 1.0 and the gearbox is outputting 1000rpm then the propshaft(s) also spin at 1000rpm
If the ratio is 1.2 then the props spin at 1200rpm,
If the ratio is 1.4 then the props spin at 1400rpm
So the lower the ratio then the easier(faster?) acceleration in lower gears, but will top out at lower speed/require higher revs to achieve the same speed > 110 XS Double Cab
Post #778773 24th Jun 2019 1:02pm
excossack
I went from 1.2 Disco in 110 td5 back to a Ashcroft 1.4 box with sleeved upgrade and ATB option.
Times where I thought I might need difflock, I haven't - overall I am happy with it. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #778822 24th Jun 2019 6:11pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
@hank
That is incorrect as I understand it.
If the output from the gearbox is 1000 rpm, the output of the transfer box would be as follows:
1.2 = 833 rpm
1.3 = 769 rpm
1.4 = 714 rpm
I find that I can actually accelerate as fast with 1.3 as I could with 1.4, I put it down to the engine spending more time in the sweet spot of the power curve due to the way a turbo diesel works.
Post #778872 24th Jun 2019 10:29pm
hank
Ahhh thanks mrd1990, so it works the opposite way round! > 110 XS Double Cab
Post #778881 25th Jun 2019 5:19am
Correct, the transfer box is a reduction gearbox, not an overdrive. The output is turning slower than the the input.
Post #778894 25th Jun 2019 6:52am
Naks
So would a Puma benefit from going from 1.2 to 1.4? --
Post #778898 25th Jun 2019 6:57am
Not unless you've put huge tyres on it. Otherwise, it'd be painfully slow and 1st would be redundant. Darren
Post #778900 25th Jun 2019 7:07am
Naks
Ah, so with the Puma, we're looking to go down, as in a 1.1 box? --
Post #778901 25th Jun 2019 7:08am
If you want to raise the gearing then yes. Darren
Post #778902 25th Jun 2019 7:12am
hank
Post #778910 25th Jun 2019 8:58am
Naks
I take it no one has done the 1.1 mod yet then? --
Post #779045 26th Jun 2019 7:31am
ashtrans
Site Sponsor
Hi,
yes, many customers have, works very well with a tuned TDCi, Dave
Post #779094 26th Jun 2019 12:07pm
Page 2 of 4 <1234>
