Home > Maintenance & Modifications > Exmoor heated seats
PeteO
England 1994 Defender 110 300 Tdi CSW Rioja Red
Exmoor heated seats
Hello again from a frequent reader (because of the mass of good content), but an infrequent contributor.
Trying to wire heated seats.
I’D like to know whether and what is the downside to the following :
The loom kit comes with a red wire that the instructions (such as they are) say should be connected to the ignition.
What would be wrong with connecting that red wire direct to the + terminal on an auxiliary battery.
I understand that the risk is that the seats are left ‘on’ by mistake, but I could cover that by battery isolation switches.
I’d really appreciate input from far more knowledgeable people.
Pete
Post #778204 19th Jun 2019 9:54pm
landy andy
I think for the exact point you wrote. You would only want the seats heated whilst the vehicle is being driven. Would be rad to rig up a relay to do this by sensing the input voltage.
Post #778208 19th Jun 2019 10:05pm
PeteO
Thanks Andy, appreciate your response.
My thinking was that I could operate the heated seats without having to have the ignition switch set to whatever is required.
Please bear in mind, i’m A complete beginner !
Pete
Post #778209 19th Jun 2019 10:54pm
PeteO
And no, i’d Want the seats to heat whilst stationary ( son plays rugby and it gats cold)
Post #778210 19th Jun 2019 10:55pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I didn't bother going through the ignition and every things been fine for the last ten years. Also been left on overnight on numerous occasions without flattening the battery. 130 crew cab
98 V8 Disco
Post #778212 20th Jun 2019 3:00am
jst
Nothing wrong with wiring as you suggest. My rear seats are wired like that. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #778217 20th Jun 2019 6:10am
PeteO
Thank you all very much for taking the time to assist a complete amateur.
I'm going to go with the original idea - seems to work for some of you.
I'll let you all know how it goes.
cheers and thanks again
Thumbs Up
Post #778233 20th Jun 2019 9:47am
PeteO
Well, I’ve done as I thought would work (and some agreed with me).
Works a treat, and I even tested the “left on by mistake” process, without needing a cut-out switch.
Came through with flying colours.
So i’m really grateful to you all.
Post #785632 7th Aug 2019 11:02pm
jst
Top news, glad it's worked sell. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #785797 8th Aug 2019 9:42pm
