Home > Maintenance & Modifications > Exmoor heated seats |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5759 |
I think for the exact point you wrote. You would only want the seats heated whilst the vehicle is being driven. Would be rad to rig up a relay to do this by sensing the input voltage.
19th Jun 2019 10:05pm |
PeteO Member Since: 17 Oct 2016 Location: Newmarket Posts: 11 |
Thanks Andy, appreciate your response.
My thinking was that I could operate the heated seats without having to have the ignition switch set to whatever is required. Please bear in mind, i’m A complete beginner ! Pete |
19th Jun 2019 10:54pm |
And no, i’d Want the seats to heat whilst stationary ( son plays rugby and it gats cold)
19th Jun 2019 10:55pm |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
I didn't bother going through the ignition and every things been fine for the last ten years. Also been left on overnight on numerous occasions without flattening the battery. 130 crew cab
98 V8 Disco |
20th Jun 2019 3:00am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8131 |
Nothing wrong with wiring as you suggest. My rear seats are wired like that. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Jun 2019 6:10am |
Thank you all very much for taking the time to assist a complete amateur.
I'm going to go with the original idea - seems to work for some of you. I'll let you all know how it goes. cheers and thanks again |
20th Jun 2019 9:47am |
Well, I’ve done as I thought would work (and some agreed with me).
Works a treat, and I even tested the “left on by mistake” process, without needing a cut-out switch. Came through with flying colours. So i’m really grateful to you all. Cheers |
7th Aug 2019 11:02pm |
Top news, glad it's worked sell. Cheers
8th Aug 2019 9:42pm |
