![]() | Home > Technical > Can anyone help identify this heated seat wiring |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5870 ![]() ![]() |
That is what you get on Exmoor trim seats. So you can either wire it up with two heats, one high heat, or one low heat. Up to you.
Think black was neg then the other two are the two heat options. |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
Thanks, I will have a go at blowing some fuses
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1467 ![]() ![]() ![]() |
Hi, it looks like a Waeco MSH heated seat kit, I have fitted one before.
I'll have a dig around at the weekend, see if I've got a better wiring diagram than this, ![]() Click image to enlarge https://www.firstfour.co.uk/waeco-heated-s...ender.html |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20751 ![]() ![]() |
You will not want the highest heat for certain. I’ve tried it and they are far too hot. The lowest heat is excellent in every way. There is the negative and the other two are both positives. One high, one low.
I’m sure if you look up Waeco heated seats on here info will come up. I think I posted the wire colours some time ago on here when I did my own. Of course if you have a 2 way switch you can use both heat settings. I wanted only one to work with genuine switches, and the lower heat setting is perfect. I’d say in standard seats the pads actually make them even more comfortable too. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Black = earth
Green = heat setting 1 (low) Red = heat setting 2 (high) |
Brilliant!
All now connected up on low heat (green) If come winter it is not sufficient I just have to swop the pins over in the plug to the red. Thank you all for the help. |
![]() Hope it's a while before we need our heated seats! Heated seats and windscreen are now essential on any vehicle for me. Not tried a steering wheel yet! |
The heated screen is the next project for me, but so far the suppliers I have contacted want pick up only and I was after it being delivered. It might have to wait so I can combine it with a show
