Home > Technical > Can anyone help identify this heated seat wiring
llessur
I am in the process of wiring up some s/h heated seats. I have installed the OEM switches through relays but I am now stuck on the wiring to the seats. I am not sure if these are LR or aftermarket but the seat base has two connector blocks one of which connects to the seat back connector. This leaves the red/black/ green wire connector to be powered up. Can anyone help with which is negative and positive. See image below
Post #778162 19th Jun 2019 7:23pm
landy andy
That is what you get on Exmoor trim seats. So you can either wire it up with two heats, one high heat, or one low heat. Up to you.
Think black was neg then the other two are the two heat options.
Post #778164 19th Jun 2019 7:38pm
llessur
Thanks, I will have a go at blowing some fuses Rolling Eyes
Post #778165 19th Jun 2019 7:46pm
DSC-off
Hi, it looks like a Waeco MSH heated seat kit, I have fitted one before.
I'll have a dig around at the weekend, see if I've got a better wiring diagram than this,
https://www.firstfour.co.uk/waeco-heated-s...ender.html
Post #778316 20th Jun 2019 9:27pm
You will not want the highest heat for certain. I’ve tried it and they are far too hot. The lowest heat is excellent in every way. There is the negative and the other two are both positives. One high, one low.
I’m sure if you look up Waeco heated seats on here info will come up.
I think I posted the wire colours some time ago on here when I did my own.
Of course if you have a 2 way switch you can use both heat settings.
I wanted only one to work with genuine switches, and the lower heat setting is perfect.
I’d say in standard seats the pads actually make them even more comfortable too. WeWillWin🇬🇧🇺🇸
Post #778320 20th Jun 2019 9:43pm
DSC-off
Black = earth
Green = heat setting 1 (low)
Red = heat setting 2 (high)
Post #778328 20th Jun 2019 10:11pm
Thumbs Up WeWillWin🇬🇧🇺🇸
Post #778339 20th Jun 2019 10:54pm
llessur
Brilliant!
All now connected up on low heat (green) If come winter it is not sufficient I just have to swop the pins over in the plug to the red.
Thank you all for the help.
Post #778531 22nd Jun 2019 6:29pm
DSC-off
Thumbs Up
Hope it's a while before we need our heated seats!
Heated seats and windscreen are now essential on any vehicle for me. Not tried a steering wheel yet!
Post #778537 22nd Jun 2019 7:33pm
llessur
The heated screen is the next project for me, but so far the suppliers I have contacted want pick up only and I was after it being delivered. It might have to wait so I can combine it with a show
Post #778548 22nd Jun 2019 8:28pm
