Home > In Car Electronics > Help wiring mudstuff winch switch
Page 2 of 2 <12
hank
I would recommend getting a genuine JLR switch and only utilising the switch front/button from the bearmach switch > 110 XS Double Cab
Post #777778 17th Jun 2019 6:17am
dantastic
Any idea which one is the cheapest genuine?
Feels like a stinger having already spent £25 on a switch ☹️
Post #777829 17th Jun 2019 1:19pm
PaulMc
The Defender Puma heated seat switch YUF500150LNF is around £10
This is a live-switching switch, which uses the Black connector.
Wiring for this switch, is as shown in the lower diagram on Bearmach's sheet, i.e. -
Pin 1 - Live in from fused supply
Pin 2 - Dash illumination
Pin 3 - Not used (but is internally connected to Pin 5 - Earth)
Pin 4 - Switched live out to accessory (relay)
Pin 5 - Earth Paul.
Post #777834 17th Jun 2019 1:34pm
dantastic
Thank you Paul!
This is the second time you come to my rescue. Years ago now I was able to add central locking to my as10 td5 following one of your guides. So once again, mucho gracias!
Post #777837 17th Jun 2019 1:52pm
dantastic
The genuine heated seat switch worked perfectly. Just plugged it in without modifying any of the wiring I’d done.
Cheap ass Chinese Censored Censored Censored crap!
I wish bearmarch would have some form of quality control.
Post #778732 24th Jun 2019 9:45am
Page 2 of 2 <12
