Home > Technical > 2015 puma - red light on dash?
kbf1981
Does anyone know what this light on the dash means on a 2015 puma? Thanks for any help! Smile
Post #776888 10th Jun 2019 10:02am
discomog
key fob battery requires replacement Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #776889 10th Jun 2019 10:04am
kbf1981
Thank you, that's ace!
Post #776893 10th Jun 2019 10:48am
macfrank
sorry not entirely true; indicates fob battery only if it flashes rapidly after 10secs.
otherwise indicates arming state.
Post #777232 12th Jun 2019 5:18pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
Could it also relate to a weak battery? I've now had it twice that this light stayed on permanently. After a short drive I turned the engine off and this light didn't come on again after restarting engine. But the mileage counter was resetted to 0. Any ideas welcome!
Edit: 2015 Puma as well.
Post #951520 4th May 2022 7:57am
nitram17
Re: 2015 puma - red light on dash?
Happened to me noticed after a hundred yards or so ,stopped the car ,switched engine off ,took key out of ignition ..restarted and it was gone! Hasn't happened again...just a glitch? mine is a MY2015 model .
Post #951562 4th May 2022 2:13pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Did you leave it unlocked for a while. Mine did this too. The immobiliser comes on after you leave the car unlocked. I think the solid red light indicates this. Stayed on even after starting, but car started and ran ok. Light went off after stopping, locking and unlocking.
2015 model too.
Post #951565 4th May 2022 2:47pm
Pat
Wales
Had the same experience, reoccurred a couple of times weeks apart. Changed batteries in both fobs today red warning light not staying on - hopefully sorted. Mines a MY2012. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #951567 4th May 2022 4:00pm
Siwynne
That’s a level crossing indicator light.
(Not really).
Mine lights up solid red if the barriers are about to come down as I approach a level crossing that I use regularly. It doesn’t if they are staying up!!
Post #951703 5th May 2022 6:37pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Occasionally mine lights up if I’m driving along and the drivers door isn’t quite shut properly. A good slam of the door and the light goes off.
Post #951714 5th May 2022 8:36pm
ngins
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
Even though I change my fob batteries very regularly since getting stuck once, this light definitely seems to come on when my fob battery is low or else when something is out of sync but a new fob battery always seems to sort it.
Post #996752 18th Jun 2023 3:19pm
