Home > Technical > 2015 puma - red light on dash? |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2532 |
key fob battery requires replacement Defender 90XS SW
10th Jun 2019 10:04am |
kbf1981 Member Since: 22 Feb 2015 Location: Manchester Posts: 183 |
Thank you, that's ace!
10th Jun 2019 10:48am |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
sorry not entirely true; indicates fob battery only if it flashes rapidly after 10secs.
otherwise indicates arming state. |
12th Jun 2019 5:18pm |
chek Member Since: 17 Sep 2015 Location: ZRH Posts: 182 |
Could it also relate to a weak battery? I've now had it twice that this light stayed on permanently. After a short drive I turned the engine off and this light didn't come on again after restarting engine. But the mileage counter was resetted to 0. Any ideas welcome!
Edit: 2015 Puma as well. |
4th May 2022 7:57am |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Happened to me noticed after a hundred yards or so ,stopped the car ,switched engine off ,took key out of ignition ..restarted and it was gone! Hasn't happened again...just a glitch? mine is a MY2015 model . |
4th May 2022 2:13pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 733 |
Did you leave it unlocked for a while. Mine did this too. The immobiliser comes on after you leave the car unlocked. I think the solid red light indicates this. Stayed on even after starting, but car started and ran ok. Light went off after stopping, locking and unlocking.
2015 model too. |
4th May 2022 2:47pm |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 368 |
Had the same experience, reoccurred a couple of times weeks apart. Changed batteries in both fobs today red warning light not staying on - hopefully sorted. Mines a MY2012. It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
4th May 2022 4:00pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 591 |
That’s a level crossing indicator light.
(Not really). Mine lights up solid red if the barriers are about to come down as I approach a level crossing that I use regularly. It doesn’t if they are staying up!! |
5th May 2022 6:37pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 337 |
Occasionally mine lights up if I’m driving along and the drivers door isn’t quite shut properly. A good slam of the door and the light goes off.
5th May 2022 8:36pm |
ngins Member Since: 15 Jan 2017 Location: Down South Posts: 87 |
Even though I change my fob batteries very regularly since getting stuck once, this light definitely seems to come on when my fob battery is low or else when something is out of sync but a new fob battery always seems to sort it.
18th Jun 2023 3:19pm |
