Home > Technical > INDICATOR FLASHER UNIT
Frunch
United Kingdom 2008 Defender 90 Puma 2.2 CSW Chawton White
Good Afternoon Forum
I have an intermittent fault on the direction indicators in my 08 registered Defender 90. Occasionally they will "hang: (i.e. just stay permanently on and not flash). This happens with both the left and right indicators. In this "hung" condition the hazard mode setting also has all the indicator permanently lights on. Having cancelled the indicator and then operating it again a couple of times clears the problem - usually.
This would seem to be a problem with the indicator flasher unit. My questions are:
1. Where is the flasher unit located in a Defender 90?
2. Is it easily accessible? (i.e. Accessible in 5 mins or does it need a couple of hours to remove fascia panels?)
3. Where is a good place to buy a replacement unit?
Thank you for any replies.
Post #776669 8th Jun 2019 11:01am
Martin
Site Admin
As it affects the indicators and the hazards it would seem to be the flasher unit.
Location given in these posts:
https://www.defender2.net/forum/post442653.html
https://www.defender2.net/forum/post565619.html
PRC8876/YWT500050/YWT10002L are the original part numbers. Genuine is ~£45+VAT, aftermarket ones a lot less (less than £10 inc VAT)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #776670 8th Jun 2019 11:11am
Organised Chaos
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
Same on my 08 earlier this year, just changed the flasher unit all ok now.
Post #776902 10th Jun 2019 12:52pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I'm on my third one. They dont seem to last very long. 130 crew cab
98 V8 Disco
Post #776903 10th Jun 2019 1:03pm
dorsetsmith
check the solder joint in the indicator unit
Post #776914 10th Jun 2019 3:18pm
