Home > Expedition & Overland > Creating or editing .gpx routes
Bluest
I have a .gpx sat nav route file that I would like to modify. I also have a written list of the corrected gps coordinates. I would like to either modify the existing file or create a new one using the correct coordinates. I am a complete newb at this, can anyone explain to me in simple terms how to do it? I have a Mac home computer and an Android tablet to use. Any help appreciated. 2007 110 TDCi Station Wagon XS
Post #776114 3rd Jun 2019 9:09pm
Eduardo
Bluest,
Usually I convert the gpx to KML or KMZ and made the mods in google earth, then move again to gpx.
Modify in google earth is quite easy, just select the route and modify the points needed
Several online converters are available in the web
Cheers Eduardo
Post #776123 3rd Jun 2019 10:03pm
Bluest
Hi Eduardo, thanks for the tip. i have managed to convert my file to .KML and uploaded it to Google Earth for Chrome. I can't use the Google Earth Desktop App as the Mac version is not current and continually crashes. I can see on Google Earth my track (in red) and waypoints (pins), but I can't work out how to make any changes to it. Can you offer any more advice? 2007 110 TDCi Station Wagon XS
Post #776194 4th Jun 2019 6:50pm
Whitcliffian
For simple .gpx file editing the EasyGPS is easy to use. (https://www.easygps.com/). Thereafter you can upload to GPS units, open in other programmes etc.
Post #776224 4th Jun 2019 8:55pm
Bluest
I think Easy GPS is PC only, I have a Mac. 2007 110 TDCi Station Wagon XS
Post #776226 4th Jun 2019 9:14pm
Eduardo
I forgot the MAC Issue...
A work around will be (if you have the coordinates that you like to change as you stated)
open the KML file as a text file.
You will find there the coordinates that compound the track in plain text after the text <coordinates>.
You can change manually and save the file for future use.
Not the best way but works.
Cheers Eduardo
Post #776230 4th Jun 2019 9:33pm
miker
https://maps.the-hug.net/
http://www.mygpsfiles.com/app/
Both are free, browser based, and allow you to import, edit and export gpx files.
Post #776251 5th Jun 2019 8:53am
Whitcliffian
I also overlooked the MAC requirement. I cannot help much beyond a web search. I guess that you have done that already so good luck & I hope that you find a good solution.
Post #776281 5th Jun 2019 1:51pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I use Google Earth Pro on a mac and it works great and doesn't crash Thumbs Up
https://www.google.co.uk/earth/download/gep/agree.html Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #776300 5th Jun 2019 4:35pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
I have the same set up as you.. Macbook pro and an Android tablet in the Landy.
On the Mac I use Garmin BaseCamp software to plan, edit, import and export gpx files. It also links directly with Google Earth so you can select a route you have imported or created and view it in Google Earth. There are lots of free Maps available on the Web that can be installed into it too.
Once I have created a route I export the gpx route from BaseCamp into my OneDrive folder so its accesible from my android tablet. On the Android Tablet I use an App called Locus Maps Pro. A great App that I can load gpx files into and then follow when I am on the trail. It is very accurate and I also use this for recording tracks as I explore. You can download Maps offline for most countries from the Locus Map store for a few pounds so its good value too.
Hope this helps but give us a shout if you need any more info.
Simon
Post #776327 5th Jun 2019 8:05pm
Bluest
The problem I’ve had with Garmin Basecamp is I can’t install the map I downloaded (an OSM one from Garmin). The Installer doesn’t seem to do anything. 2007 110 TDCi Station Wagon XS
Post #776329 5th Jun 2019 8:09pm
geobloke
If you want a solution for both mac and windows then have a look at QGIS. It is freeware. It is the equivalent of ARCGIS if you know it.
https://www.qgis.org/en/site/
Although I have not done it, it will allow for the import of Garmin OSM data (via a pluggin) and the editing of GPX point data.
The other option is GPS Utility which will pretty much open edit and save any GPS data. But only in windows.
http://www.gpsu.co.uk/download.html
Another is TwoNav which will do what you want on Windows and Mac as well. The Land software is very good and has an app for your phone or ipad.
https://www.twonav.com/en/software
Post #776352 6th Jun 2019 7:05am
Bluest
Thanks for all the input Thumbs Up I need to take a few days to go through the options suggested to see what might work for me. Will report back. 2007 110 TDCi Station Wagon XS
Post #776399 6th Jun 2019 6:36pm
