Home > Puma (Tdci) > Summer starting and high oil temperature
Bourgui
Oman 2010 Defender 110 Puma 2.4 DCPU Alaska White
Hi All,
now that summer started in the Middle East, we had few days over 40C. Car is driving fine except for a medium loss of power due to upgraded intercooler on its way out. (I am working on the warranty now, should be solved soon).
My worry is that both EGT and coolant temps are stable and within the usual range (300C post turbo & 82C with PEL500110) when driving 110 km/h on the flat, but the engine oil temps climbs up to 90C (usually 72/75C in our "winter") then goes down to 78C for no reason and black slowly to 90C and so on.
Shall I be worried? Any explanation? Can this be caused by IC leak?
Thanks in advance
Post #771066 1st May 2019 3:54pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
90 doesn’t seem high. Mine Goes up to 100. Hot weather, 4 kids, a caravan and up the Mountains. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771068 1st May 2019 4:21pm
ARC99
Don't ask me how you check it.
The oil filter has a cooler that is fitted with a thermostat on the intake side. Don't make old people mad.
Richard
Post #771098 1st May 2019 7:35pm
Bourgui
Thanks both for your inputs!
Regarding the thermostat, has anybody drilled it to have it all the time? Temperature over here never gets below 20C so it should not cause any trouble?!?
Post #771148 2nd May 2019 4:45am
Retroanaconda
The vehicle is built for it, don’t worry and you’ll enjoy it more.
Post #771151 2nd May 2019 5:43am
Tdi4
Jup no problems. Btw it’s the PEL500110 thermostat. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771156 2nd May 2019 6:31am
