Home > Maintenance & Modifications > 2015 Service schedule
ant.
Can anyone point me to a service schedule for my 2015 90 HT please?
AS it is now out of warranty I am looking at DIY maintenance, any reason not to???
Post #770657 29th Apr 2019 11:16am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Nope not at all Laughing
If you also have OCD like me you'll do a much better job that the workshop.
If found countless Big Cry problems which the workshop hasn't discovered or hasn't be able to repair. I'm going through them one by one. If anything goes wrong i have only myself to blame Laughing and in any case it's a lot cheaper than the workshop not to mention the dealer.
p.s. i'am working on an extended service spreadsheet since the LR maintenance doesn't cover all the areas (ie I check injector seals regularly) a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770663 29th Apr 2019 11:40am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi Ant
you will learn a lot about the vehicle, know the job has been done properly and saved ££££.
As you are saving you can justify genuine filters etc Thumbs Up
Post #770666 29th Apr 2019 12:01pm
ant.
That the kind of thinking I am going for
Post #770668 29th Apr 2019 12:12pm
ant.
Cheapest I have paid since buying it from LR is £349 for an A service
Post #770669 29th Apr 2019 12:13pm
ant.
A member has very kindly sent me the schedule,
is it the same for a 2.2 as a 2.4 Puma?
Post #770681 29th Apr 2019 1:47pm
macfrank
You can download individual lists at https://osh.landrover.com
Just enter your VIN (the site does no longer need a registration)
Post #770729 29th Apr 2019 5:58pm
