Home > Maintenance & Modifications > 2015 Service schedule |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
Nope not at all
If you also have OCD like me you'll do a much better job that the workshop. If found countless problems which the workshop hasn't discovered or hasn't be able to repair. I'm going through them one by one. If anything goes wrong i have only myself to blame and in any case it's a lot cheaper than the workshop not to mention the dealer. p.s. i'am working on an extended service spreadsheet since the LR maintenance doesn't cover all the areas (ie I check injector seals regularly) a defender from 1984 pretending to be a puma with a touch of Range Rover |
29th Apr 2019 11:40am |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Hi Ant
you will learn a lot about the vehicle, know the job has been done properly and saved ££££. As you are saving you can justify genuine filters etc |
29th Apr 2019 12:01pm |
ant. Member Since: 14 May 2016 Location: staffordshire Posts: 6 |
That the kind of thinking I am going for
29th Apr 2019 12:12pm |
Cheapest I have paid since buying it from LR is £349 for an A service
29th Apr 2019 12:13pm |
A member has very kindly sent me the schedule,
is it the same for a 2.2 as a 2.4 Puma? |
29th Apr 2019 1:47pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
You can download individual lists at https://osh.landrover.com
Just enter your VIN (the site does no longer need a registration) |
29th Apr 2019 5:58pm |
