Home > Wheels & Tyres > Wolf wheels - what tyre size?
Page 2 of 3 <123>
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I've taken my wheels and tyres ready to have the rims painted and the tyres fitted this afternoon, but although I've used them before, the place hasn't exactly inspired confidence.
I want the wheels to be Fuji white, but after being told 'they'd look good in black' (maybe, but I want them Fuji white!) the firm seem to think it's going to be difficult to avoid it yellowing in their ovens. I've told them if they can't do it, I'll have them back and try elsewhere, but I'm waiting to see what happens.
I wonder how LR painted their Wolfs originally?
Post #785043 5th Aug 2019 6:41pm
JOW240725
I think I'd be walk8ng away trying somewhere else. James
Instagram @suffolk_rovers
Post #785100 5th Aug 2019 9:27pm
90 Dreamer
given the amount of plain white wheels then not sure how a powder coater ends up with them Yellow??
Post #785161 6th Aug 2019 8:51am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I was thinking about having my Wolf wheels painted white, but I just discovered the 8J wheels from Nakatanenga are finally available. Would mean my 235 tires look sh!t on those resulting in new tires as well? Choices... Still tempting. Whistle
https://www.nakatanenga.de/en/vehicle-equi...l-rim-8x16
Post #785174 6th Aug 2019 10:12am
Joe the Plumber
The firm rang me yesterday to say they needed my paint code as they are going to get the rims sprayed with two pack so they will exactly match the rest of the van.
Apparently, they only have one 'standard' white with their powder coating process which is too creamy once it's been baked, but by painting them (onto a powder coated primer), they'll be right.
As I was originally going to get them painted in any case, I'm happy with this.
I'll post some photos when I get them back, hopefully next week sometime.
Post #785641 8th Aug 2019 6:07am
hxk494
what size tyres do you reckon would be needed to do those rims justice? 1996 300Tdi Defender 110
Post #785722 8th Aug 2019 4:03pm
Anything from 265mm to 295mm if you work of BFG recommended rim widths. I bet they'd look good with 285s.
Post #785730 8th Aug 2019 4:35pm
Joe the Plumber
I should get my wheels back from painting and tyre fitting today.
I'll update this in a bit if it works out (I have a feeling there will be "complications"....)
Post #787125 16th Aug 2019 6:46am
tookaphotoof
I’m thinking the same, although I have a feeling 265 would be the better size for me.
Post #787128 16th Aug 2019 7:07am
Joe the Plumber
Well, I've got four of them back, but there was a slight issue with the paint on the other one so they're having another go at that. I think it will be another week before I can post any photos now I'm afraid.
By gum they do look good though (perfect Fuji white paint match and shiny - phew!)
PS - no offence at all intended, but how about starting a separate 'Nakatanenga 8J wheel' thread please chaps? The info on them will doubtless be very useful, but it's surely likely to get lost in future in a thread headed 'Wolf wheels - what tyre size?'.
Post #787183 16th Aug 2019 4:30pm
Joe the Plumber
I finally started using the van with the Wolfs yesterday and my immediate impression is that the 235/85/R16s are a bit larger overall diameter than the 750/R16s which has had a slight effect on the gearing. I seemed to need to change down a bit more than previously.
Interestingly, the width of the actual tread is at most only about 1/4" wider on the 235s than the 750s. The width over the sidewalls is a lot more, but I was surprised about this. On reflection, I'd have taken the earlier good advice in this topic, saved myself £500 and had my 750s put on the rims.
I'll try to get a photo up later.
Post #789029 28th Aug 2019 6:53am
On paper, 235/85's and actually slightly smaller than 7.50's although it's so close that you wouldn't be able to tell the difference. Your need to change down more is probably due to the increased rolling resistance rather than gearing.
Look forward to the pictures. Darren
Post #789038 28th Aug 2019 8:08am
By my reckoning a 235/85 is actually about 3/8" taller in section than a 7.50, so the overall diameter of a 235/85 would nominally be 0.72" larger. However this is insignificant in real terms, and the amount of wear, the tread pattern etc., is likely to make more difference.
Post #789046 28th Aug 2019 8:32am
Ah, you're right! I was thinking of the difference between a 235/85 and a 265/75 Rolling Eyes Darren
Post #789053 28th Aug 2019 8:43am
Joe the Plumber
Thanks chaps. Having stood one of each wheel next to each other before I fitted them, I can confirm the 235s are definitely a slightly larger overall diameter than the 7.50s, but as I said above, there's hardly any difference in the width of the tread itself.
Post #789131 28th Aug 2019 1:43pm
Page 2 of 3 <123>
