Home > Series Land Rovers > Aluminium. Vapor blasting or hand finish |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2530 |
If you want the best possible finish then vapour blasting is the way to go. Gives aluminium casting that brand new finish. Defender 90XS SW
7th Apr 2019 7:29am |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
I would agree that vapour blasting is excellent for cast aluminium parts, I have used it a lot on my Series vehicles engine parts.
7th Apr 2019 10:11am |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 |
Thanks for the heads up. Does it stay close to cast finish? I want to replicate the original look as much as possible. m
8th Apr 2019 6:51am |
Vapour blasting is not as aggressive as grit, sand or bead blasting, due in the main down to the use of water as a lubricant. If you know a local company that carries out vapour blasting why not ask them to show you some examples of their finished work. Defender 90XS SW
8th Apr 2019 7:13am |
Thanks for all your answers. Convinced. Will post some pictures once done. m
8th Apr 2019 9:17am |
