Home > Series Land Rovers > Aluminium. Vapor blasting or hand finish
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Anyone know what JLR Classic is using to restore their aluminium parts? I get good results with brushing but still wondering if I should get them vapor (not soda) blasted to keep them 'clean for longer.m
Post #767328 7th Apr 2019 6:20am
discomog
If you want the best possible finish then vapour blasting is the way to go. Gives aluminium casting that brand new finish. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #767343 7th Apr 2019 8:29am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I would agree that vapour blasting is excellent for cast aluminium parts, I have used it a lot on my Series vehicles engine parts.
Post #767380 7th Apr 2019 11:11am
100inch
Thanks for the heads up. Does it stay close to cast finish? I want to replicate the original look as much as possible. m
Post #767540 8th Apr 2019 7:51am
discomog
Vapour blasting is not as aggressive as grit, sand or bead blasting, due in the main down to the use of water as a lubricant. If you know a local company that carries out vapour blasting why not ask them to show you some examples of their finished work. Defender 90XS SW
Morgan Plus 8
Post #767543 8th Apr 2019 8:13am
100inch
Thanks for all your answers. Convinced. Will post some pictures once done. m
Post #767567 8th Apr 2019 10:17am
