Home > In Car Electronics > National luna
Bongo1
National luna
Long story short I have just replaced my luna dual charge system , ended up been the controller Big Cry , Anyway new one links batteries after 2 mins , instructions says a 5 mins timer , I have contacted the seller and they say it should be fine . .? Guess they would. I will email Luna direct in the USA , but if anyone else has a Luna system does yours connect in 2 mins , just seems a short time for the main battery to grab the initial solo charge .
Post #767213 6th Apr 2019 4:10pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Nope - about 5 minutes.
Just had to replace the controller due to a short. New one connects at about the same time.
System has been fitted for the last 8 years without an issue until recently and then it was my fault no the system. 2007 TD5 90 Hard Top
Post #767499 7th Apr 2019 8:24pm
Bongo1
That's what i thought 2mins was a bit short , So it should be 5 mins . my old one it was longer than 2 .
when you say controller , do you mean the remote monitor , or the controller on the solenoid
Post #767513 7th Apr 2019 9:08pm
Landlord
Remote monitor.
When reconnecting batteries after removing them I shorted the monitor accidentally Embarassed
Had to buy a new monitor, quick to change over and all working fine since then. 2007 TD5 90 Hard Top
Post #768067 10th Apr 2019 7:44pm
Bongo1
Quick follow up , on the solenoid the grey base plate has a 2 min timer the black base has a 5 MIN TIMER .
Post #768159 11th Apr 2019 3:01pm
