Home > In Car Electronics > National luna |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Nope - about 5 minutes.
Just had to replace the controller due to a short. New one connects at about the same time. System has been fitted for the last 8 years without an issue until recently and then it was my fault no the system. 2007 TD5 90 Hard Top |
7th Apr 2019 8:24pm |
Bongo1 Member Since: 02 Nov 2018 Location: Cheshire Posts: 815 |
That's what i thought 2mins was a bit short , So it should be 5 mins . my old one it was longer than 2 .
when you say controller , do you mean the remote monitor , or the controller on the solenoid |
7th Apr 2019 9:08pm |
Remote monitor.
When reconnecting batteries after removing them I shorted the monitor accidentally Had to buy a new monitor, quick to change over and all working fine since then. 2007 TD5 90 Hard Top |
10th Apr 2019 7:44pm |
Quick follow up , on the solenoid the grey base plate has a 2 min timer the black base has a 5 MIN TIMER .
11th Apr 2019 3:01pm |
