Home > My Defender > My USW |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3149 |
Camel-tastic!
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
15th Sep 2012 8:59pm |
Click image to enlarge :evil: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th Nov 2012 9:06am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Oh dear, time to get a stainless set ordered! 2005 Td5 | 90 Station Wagon | Tonga Green
11th Nov 2012 9:34am |
Its only 18 months old, shouldn't be doing that anyway. I have just been out and taken pics of all the other rot - really not good enough on a 18 month old car that has been fully serviced and looked after.
11th Nov 2012 9:38am |
Rot starting on underside of rear step -
Click image to enlarge Floor channel by rear door - Click image to enlarge The culprit is the bits of wire sticking out of the door seal - Click image to enlarge Both sides are the same - Click image to enlarge Rot showing through on bulkhead - Click image to enlarge Has anyone had similar kinds/areas of rot dealt with on warranty, what were your experiences please. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th Nov 2012 10:22am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2637 |
i have, good experience all replaced... Lr told the body shop to grind it then recoat, body shop argued it out ended up it all replaced properly..
11th Nov 2012 12:34pm |
I notice you have mentioned an issue with rust on your wheel studs; and earlier in the thread someone had commented on the length of them, with you replying that the dealer had said they were the right ones for the hd wheels. Maybe you could ask them again and mention the longer wheels studs available and whether they should have been fitted in the first place.
Having two reasons to swap them, rather than just one, may tip the issue in your favour? |
11th Nov 2012 1:13pm |
I might just mention that. The thing is I don't know of anyone else who has factory-fitted HD rims on a non-HD vehicle. if anyone does, what kind of studs do you have?? |
11th Nov 2012 7:38pm |
Thats reassuring, at least I can point them towards this thread then in case of any reluctance. I hate feeling so negative about dealers but you hear so many bad stories. Not sure yet if I will go back to the selling dealer in London (not very convenient for me in North Oxfordshire) or someone more local. I don't know where Jezza is now...would have gone to him. |
11th Nov 2012 7:39pm |
mines going back in too, got a long list to be done when i have it serviced, plenty more corrosion to sort out leaky seals etc.. service manager is fine with it all, ive got to call him a week before with any more problems i want sorting. |
11th Nov 2012 7:45pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 712 |
They must be the cheaper A2 stainless that still corrodes you need some A4 :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
11th Nov 2012 7:47pm |
Whatever they are is what the factory fitted! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
12th Nov 2012 3:35pm |
Bobble Member Since: 21 Aug 2011 Location: Hampshire Posts: 223 |
I've got the same on my 90. Wolf rims on standard studs. No issues in over 20k miles. |
15th Nov 2012 12:55pm |
Glad to know its not just mine then. Nothing to report really on my 110, the heated screen has been a real boon on these cold dark starts/finishes, clears the screen in no time. What I have found however is that if you have, say, the lights and heated seats on, it takes quite a bit longer to heat up, so I just let the screen run and then put whatever else on once it has cleared. The side demisters are a bit poor though aren't they, I never seem to get very much air pressure out of them even with the fan on full blast.
What is worrying me in these cold times is that I am almost never getting the engine up to temp, I only work a few miles from home and it is not long enough to heat the engine up, even with the rad muff. I do try and give it a nice long run on a weekend to warm it through properly... |
11th Dec 2012 10:47am |
