Home > Maintenance & Modifications > Soft A Bar Light sizes
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Anyone know the largest dimension of lights that can be mounted on the Soft A Bar.
Assume 7" is standard, 9" too big? LED light bar an option too, size / length?
Thanks Thumbs Up
Post #762900 11th Mar 2019 3:35pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
9” fit just
Post #762926 11th Mar 2019 7:51pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I’ve got Cibie 9” LED super oscars and they fit spot on 👍
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #762953 11th Mar 2019 10:11pm
Likeomg
Lazer rs8 fits nice,
I had a longer Chinese bar in there in the past, output was a lot less than the smaller Lazer bar tho.
Post #762958 11th Mar 2019 10:31pm
2010Blackdefender90
Thanks everyone
Post #763168 13th Mar 2019 11:18am
Fiebre
Spain 2008 Defender 90 Puma 2.4 SW Java Black
Hi,
And what should be the best harness for this lights in the A-Bar? any reference and supplier for the harness to mount it?
Post #763254 13th Mar 2019 7:08pm
2010Blackdefender90
I have used a Lazer harness, which is pre-wired, on to the LED, so any should be fine to match your make of lights, with the right water tight connections
Post #763360 14th Mar 2019 10:43am
Likeomg
Yup, I had a light force loom in from when I had spots, carried this over with my Chinese lighter
when I installed all the laser products I used there specific wiring harness. the RS8 had a few more cables, the triple R on the roof is a fairly high output LED
Post #763383 14th Mar 2019 12:05pm
Fiebre
light weight on soft A Bar
Hi,
Does anybody know the weigth of each light that can the soft A bar can support?
I have the LR006415 to mount but I want to hang up on the A bar the lights.
What is your opinión?
Thanks,
Post #824501 10th Apr 2020 10:03pm
