Home > Puma (Tdci) > Modifications and emissions
redline
Switzerland
Hoping some of you experts can give me some insights about emissions - or specifically the effect of modifications on the emissions level.
Here is the situation: I am about to register my 2009 TDCI 110 in Switzerland. The car is EU spec, but imported it from outside the EU. Part of the registration process is the technical inspection (equivalent to MOT) and the dreaded emissions test. JLR Switzerland states that the vehicle is Euro 2, which is odd given that Euro 4 came into effect in 2006...
I'm assuming that the vehicle will be tested for NOx and CO emissions. Ignoring for the moment the actual levels, I was wondering how the following would potentially affect the emissions:
1. Removal of the CAT.
2. Removal of the centre-box
3. Typical re-map (eg BAS or Alive)
4. EGR delete
5. Premium fuel (eg BP Ultimate, Shell V-Power, etc...)
6. Fuel additives (Wynns Extreme, 2-stroke oil, etc...)
Many thanks in advance for the insights...
Post #760195 22nd Feb 2019 6:01pm
MK
Not an expert at all. But cat removal and remap are likely to be an issue. Egr as well as it reduces the combustion temps (ie NOx). Liqui moly and others sell aditives to reduce smoke (and CO). Puma 110" SW
Post #760198 22nd Feb 2019 6:21pm
smb
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Redline,
I’ve had everything you’ve mentioned done and with a current mileage of over 160k miles was Giving out readings of very low emission levels. Testing station stated that levels were lower than most new cars less than 12months old. Will look at certificates and post what the levels were.
One thing I would say is that the quality of the fuel does have an effect. I run Millers additive and 2-stroke and there was a big difference between running a tank of supermarket fuel and bp ultimate. I did put the finding/details on another thread on here but can’t remember which one.
Post #760224 22nd Feb 2019 8:06pm
Bear in mind that the UK MoT does not test for NOx, which is what the EGR is designed to reduce. If the Swiss test does, then it'll likely fail. Darren
Post #760245 22nd Feb 2019 9:09pm
ericvv
Redline, so you imported a MMR 2.4 Puma (Minor Markets RHD) which replaces the old ROW expression. Those early Pumas often were indeed built to EU2 emissions only. Guess that means they do not even have a CAT or an EGR.
Importing those into Switzerland is no problem, but I'm afraid you may run into a wall with our tech inspection unlikely to approve any 2007 built vehicle which is only EU2 (not even EU3).
What are JLR Switzerland telling you about the chance to get a pass and get it registered here?
Good luck, would be interesting to hear how you fare.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #760283 23rd Feb 2019 6:20am
redline
Switzerland
Gents,
Thanks for the many helpful inputs.
MK -Agree on the EGR, but i've heard varying opinions on the CAT and re-map. Although the removing the CAT will have a negative effect on emissions, its not measured in the tests. Also, some claim that a re-map will potentially reduce emissions because of increased efficiency - which squares with some reports of improved mileage.
SMB - I've also experimented with 2-stroke oil. The car definitely seems to run smoother when using it with crappy Diesel - feels closer to premium fuel. Amazing that your engine is performing so well!
Anorak - Surprised the tests don't cover NOx, as these are legislated values?!
Ericvv - Its a LHD so not sure about it being an MMR? I definitely had a CAT (now removed, and can be replaced) and the EGR is fully functional. To confuse matters further, JLR Italy have said it is 2003/76B/CE compliant, which I have been told is "equivalent" to EU4. In any case all the documentation has been approved by MFK, but they did not state to what standards the tests will be conducted. As I understand it, they will use the first year of registration to define which standards it needs to comply with. So that would be 2010, which is EU4 I think.
Post #760328 23rd Feb 2019 10:55am
There's talk of it being introduced but, apparently, the necessary kit is prohibitively expensive at the moment. Darren
Post #760362 23rd Feb 2019 2:25pm
