Home > Technical > Puma 2.2 Turbo Inlet pipe problems |
British Bulldog Member Since: 17 Feb 2019 Location: Soth East Asia Posts: 10 |
Hi all, had my 130 Defender for 4 years now and only done 40,000 klms however, the turbo inlet rubber tube has split 4 times (and I suspect its gone again), she's just gone into Limp mode which is typical when this happens, the rubber elbow tube connected to the turbo inlet keeps splitting .... is there a factory mod to stop this happening, or an accessory (Heavy duty tube or stainless steel mod /) That can cure the problem ?[size=18][/size] Cheers and thanks for any advice
17th Feb 2019 2:49am |
A good idea however, the hose in question is custom made to be slightly larger on one end than the other ...
Thanks ! |
17th Feb 2019 8:56am |
