Home > Puma (Tdci) > Alternator refit
snowric
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Galway Green
Alternator refit
OK, alternator failed, battery light.
I've managed to get the old one off and out but I just cannot seem to get the new one to stay put so I can gently wind in the top bolt. TOp bolt and threadsd are fine - I've checked without the alternator..
Havgin tried to use the belt to hold it up, I think it probably needs someone underneath supporting the not inconsiderable weight of the generator.
Any tips gratefully received.
My 9 year olod wasnnot impressed as I tried to get it on myself last night.
Apparently i was swearing a lot and she sleeps right above where I was working.
Big Cry Snowy
Post #758317 13th Feb 2019 9:04am
Eduardo
Snowric
I do the same work some time ago.
definitely is not a easy for just one person (almost impossible).
Finally I receive the help of my son to put the alternator in place and be able to fix the bolts.
Cheers! Eduardo
Post #758356 13th Feb 2019 12:21pm
It's shocking the LR of over £400 for one exc labour.
Could you have tried luggage straps / tie downs? TheThunder Rolls🇬🇧🇺🇸
Post #758412 13th Feb 2019 4:50pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Re: Alternator refit
Big Cry
Ear plugs or a more "peaceful" bedroom for your daughter Rolling with laughter
Post #758448 13th Feb 2019 7:01pm
snowric
Very encouraging !!!
I found that if you pull the the serpentine belt around the alternator pulleythen you can use the belt to lift the alternator near the top bolt. I also removed the turbo air inlet - careful there is a rubber gasket in there. This gave me room to get my right hand in hold it. A bit hit and miss but a nights sleep and a day at work seemed to make it all doable.
I used a transit alternator aftermarket from Rimmer Brothers where I get a lot of Triumph stuff too. Let’s see how long it lasts.
Btw, I thought these had a freewheel pulley but mine is locked solid to the rotor.
Am I imagining this ? Snowy
Post #758491 13th Feb 2019 9:49pm
IIRC the factory Alternator is freewheel, supposed to save fuel I think and increased efficiency. (Don't quote me on that.)
That thought is a bit sketchy though.
I can't imagine why LR would be though abd the transit type not. Confused TheThunder Rolls🇬🇧🇺🇸
Post #758503 13th Feb 2019 10:16pm
HardCharger
Given the current location of the alternator, would we benefit from a relocation kit to mount it up higher in the engine bay? In it's current location, dunking it a few times via flood or river crossings will eventually kill it. As already stated, working with it in its current location is no picnic.
I discovered a company in Australia making totally sealed alternators and they are cooled by being plumbed into the coolant stream. Unfortunately, they only do L@nd Crui$er alternators for now. If someone can come up with something like that for us Puma owners, it will be an expensive but really worthwhile upgrade.
If budget is a concern, the aforementioned proposed alternator relocation kit will make more sense.
What do all y'all think?
Post #758532 14th Feb 2019 1:48am
One attraction of a relocation kit would be the elimination on non-a/c vehicles of that absurd bracket that holds the alternator and the a/c compressor. It is a ridiculous thing that makes access to the fixings for the front branch of the exhaust manifold next to impossible!
I don't see why the alternator couldn't be moved to a location similar to the a/c compressor if you don't have a/c.
Post #758562 14th Feb 2019 9:13am
HardCharger
True enough, blackwolf. A definite advantage for owners with no A/C. A solution for owners with A/C would be nice too!
I can't see why it can't be done though, some engines have this option.
Post #758741 15th Feb 2019 2:18am
Mechman make great HO Alternators, but getting a fit maybe easier said than done without being a one off order!
Is there any equivalent in the USA in the Ford line that would fit the 2.4 block? TheThunder Rolls🇬🇧🇺🇸
Post #758816 15th Feb 2019 12:42pm
