Home > Puma (Tdci) > Alternator refit |
Eduardo Member Since: 28 Aug 2008 Location: Regiรณn Metropolitana Posts: 2110 |
Snowric
I do the same work some time ago. definitely is not a easy for just one person (almost impossible). Finally I receive the help of my son to put the alternator in place and be able to fix the bolts. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Feb 2019 12:21pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
It's shocking the LR of over ยฃ400 for one exc labour.
Could you have tried luggage straps / tie downs? $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
13th Feb 2019 4:50pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Ear plugs or a more "peaceful" bedroom for your daughter |
13th Feb 2019 7:01pm |
snowric Member Since: 01 Aug 2011 Location: London Posts: 20 |
Very encouraging !!!
I found that if you pull the the serpentine belt around the alternator pulleythen you can use the belt to lift the alternator near the top bolt. I also removed the turbo air inlet - careful there is a rubber gasket in there. This gave me room to get my right hand in hold it. A bit hit and miss but a nights sleep and a day at work seemed to make it all doable. I used a transit alternator aftermarket from Rimmer Brothers where I get a lot of Triumph stuff too. Letโs see how long it lasts. Btw, I thought these had a freewheel pulley but mine is locked solid to the rotor. Am I imagining this ? Snowy |
13th Feb 2019 9:49pm |
IIRC the factory Alternator is freewheel, supposed to save fuel I think and increased efficiency. (Don't quote me on that.)
That thought is a bit sketchy though. I can't imagine why LR would be though abd the transit type not. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
13th Feb 2019 10:16pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 737 |
Given the current location of the alternator, would we benefit from a relocation kit to mount it up higher in the engine bay? In it's current location, dunking it a few times via flood or river crossings will eventually kill it. As already stated, working with it in its current location is no picnic.
I discovered a company in Australia making totally sealed alternators and they are cooled by being plumbed into the coolant stream. Unfortunately, they only do L@nd Crui$er alternators for now. If someone can come up with something like that for us Puma owners, it will be an expensive but really worthwhile upgrade. If budget is a concern, the aforementioned proposed alternator relocation kit will make more sense. What do all y'all think? |
14th Feb 2019 1:48am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
One attraction of a relocation kit would be the elimination on non-a/c vehicles of that absurd bracket that holds the alternator and the a/c compressor. It is a ridiculous thing that makes access to the fixings for the front branch of the exhaust manifold next to impossible!
I don't see why the alternator couldn't be moved to a location similar to the a/c compressor if you don't have a/c. |
14th Feb 2019 9:13am |
True enough, blackwolf. A definite advantage for owners with no A/C. A solution for owners with A/C would be nice too!
I can't see why it can't be done though, some engines have this option. |
15th Feb 2019 2:18am |
Mechman make great HO Alternators, but getting a fit maybe easier said than done without being a one off order!
Is there any equivalent in the USA in the Ford line that would fit the 2.4 block? $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
15th Feb 2019 12:42pm |
