Home > Technical > Blowing Reverse Lamp Fuse
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
I had the reverse lamp burned out, so I thought. Fitted a new fuse, worked fine. Have since swapped for an LED bulb which was great and worked well for a few weeks. Blew Fuse again.
All the common issues of the reverse switch that I am reading about doesnt seem to be the cause. 2014 puma. Can I replace with higher amp to see if that helps?
Post #757389 8th Feb 2019 7:33pm
lohr500
As the LED bulb should draw minimal current, I would not replace with a bigger fuse.
The fuse is there for a reason Very Happy
My guess is there must be a problem with the wiring going to earth somewhere.
A case of tracing it back and eliminating each section Sad
Post #757401 8th Feb 2019 7:57pm
big110
Me was afraid you were gonna say that mate!!! ughhhh Crying or Very sad Evil or Very Mad
Post #757403 8th Feb 2019 8:01pm
^^^^ Agree, certainly don't increase the fuse rating it's there for s reason to protect the circuit and wiring.
There will either be a switch failure, short in the live or a poor earth.
My guess would be the switch, but do some testing with a Multimeter to determine there is suitable voltage at the plug and low resistance on the Earth line again at the plug.
Is the plug and socket got wet in it at all? KEEP CALM AND Drill ON
Post #757406 8th Feb 2019 8:02pm
big110
Re: Blowing Reverse Lamp Fuse
[quote="big110"]I had the reverse lamp burned out, so I thought. Fitted a new fuse, worked fine. Have since swapped for an LED bulb which was great
Post #947208 27th Mar 2022 6:09pm
