Home > Puma (Tdci) > TDCI full engine recondition
Page 1 of 3 123>
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
I'm seriously contemplating having a full engine recondition on my 2007 TDCI. It's sounding like a bag of nails particularly when cold with one particular piston con rod clanking. The timing chain is also noisy as is the top end valve gear so maybe it's time for some rework.
I've looked for suitable engine re builders and there are lots out there but who do I trust. I'm looking for recommendations.
Has anyone come across Fresh Engines UK for instance. They advertise on Ebay and on paper sound good but who knows. I tried finding them on companies house and they don't appear to be registered so I'm very wary.
Any recommendations would be welcome "You are never to old to learn something new"
Post #756864 6th Feb 2019 8:38pm
Sulisuli
Very interested to know how you get on with this, my wife’s 2007 benefit from this Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #756870 6th Feb 2019 8:53pm
JOW240725
There was a company at LRO Show, that did just this, but for the life of me can't remember the name. Give me a bit of time. James
Instagram @suffolk_rovers
Post #756886 6th Feb 2019 9:23pm
landy andy
Turner engineering. They have always done LR stuff
https://www.turnerengineering.co.uk/engine-reconditioning-process
Post #756892 6th Feb 2019 9:29pm
Retroanaconda
Turners are the go to for anything relating to Land Rover engines.
Post #756909 6th Feb 2019 9:55pm
B4Lamb
Okay,
I'll look them up and make enquiries. It would be nice though if one of the Forum members have had a full recon so they can relay their experience of the actual job I want done. Genuine testemonials if you like. "You are never to old to learn something new"
Post #757121 7th Feb 2019 5:51pm
Turners only appear to sell new short engines rather than recon existing ones.
I'm sure I read somewhere that there's an issue with availability of some of the components that would be needed for a recon, making it impractical at the moment. Darren
Post #757150 7th Feb 2019 7:26pm
B4Lamb
The Puma engine is so common I find it odd that there are shortages of bearings, shells, rings etc. There are quite a few out there offering full recons but I just don't really trust them. If Turners have new short engines these would have been built at Fords (for transits) I would think. "You are never to old to learn something new"
Post #757167 7th Feb 2019 8:18pm
The description on their website advised that the sump needs to be changed for a LR one, so almost certainly, yes. Darren
Post #757171 7th Feb 2019 8:23pm
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
I have a full rebuild kit ordered from Lyme Engine Parts. Cost $1400AUD landed.
Mine cracked #4 piston but I caught it before it damaged the block.
I have stripped the engine and will reassemble when I can find time.
Everybody here told me the engine was not able to be rebuilt because of the tolerances.
The manual calls for a lot of Land Rover special tools but you can do it without any.
Complicated engine in the fact that the they are a modular engine which everything bolts to the block, rocker girdle, head, block, crank girdle, adapter plate.
I had various options new engine, rebuilt engine fix my own.
A rebuilt engine was dearer than a new one of the Indi's.
You need to buy a new sump and timing cover as these are one use items only.
Mark
Post #757183 7th Feb 2019 8:52pm
Caterham
can you explain why the sump is a one use item?
I presume in the case of the rocket cover because it's plastic but again I'm surprised it can't be re-used?
Post #757189 7th Feb 2019 8:56pm
B4Lamb
I knew the timing chain cover needs to be a new one as it's glued on and during removal it seems it's imposiblecto prevent distortion. I was not aware the sump cannot be reused. "You are never to old to learn something new"
Post #757208 7th Feb 2019 9:19pm
B4Lamb
I'm wondering what value Turner Engineering are adding when they are selling new Ford short engines? Is the timing chain the same? I always thought the transit used a toothed belt. "You are never to old to learn something new"
Post #757209 7th Feb 2019 9:22pm
Big Harold
They are both pressed metal and very thin, both glued on.
you could possibly reuse if you are carefull with removal but both are cheap to buy so not worth the trouble.
mark
Post #757213 7th Feb 2019 9:29pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Be very very careful when looking in to recon engines there's lots of tricks and some very dishonest people in this game ,turners have a very good name but good recon firms are rare .Sorry to be negative.
Post #757219 7th Feb 2019 9:43pm
Page 1 of 3 123>
