![]() | Home > Puma (Tdci) > MT82 common failures |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Thanks for the information Dave, kind of you to share.
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
There certainly are, and I am convinced that a lot of the perceived gearbox quality is driven by other factors such as the backlash in the rest of the transmission, which upsets the syncros in the gearbox. I've proven in the past that a defective component down the line (collapsing front diff centre is the favourite) will absolutely destroy gearchange quality on an R380, I presume it's because there is 'bounce' in the system with all the slack. It's probably the reason why the MT82 (which I assume is what is fitted in the Transit and Ranger installations) is fine in those cars but more often than not has a lousy gearchange in the Defender. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 ![]() ![]() ![]() |
Just to give a bit of balance, we all hear how Toyota's are better vehicles but I've had five of them, the only difference between LR and Toyota gearbox's is that Toyota's are 5 times more exxy to fix. Unfortunately things break, I'd rather LR spend extra money on the clutch and adapter personally.
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Also, drivers with mechanical sympathy may be more prone to frequent oil changes... I wonder if regular maintenance with top quality oils can contribute to longevity...? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
My other 4x4 vehicle requires gearbox oil change every 30kkm. Same oil specs: PAO 75W-90 GL4 Puma 110" SW
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 260 ![]() ![]() |
Hi,
I mentioned earlier one problem we see are damaged casings from props letting go, this one must of made some noise !! ![]() |
I have seen that case as well from a brand new 130 used by a mining company. Puma 110" SW
another one on the bench today, we have seen this a few times before, the 3rd gear is made in 2 parts and electron beam welded together, the weld breaks and you loose drive in 3rd, selects fine but you lift the clutch and no drive :
Dave (ashtrans) - I really hope you guys manage to sort-out the gearbox, so when mine's due replacement/refurb, I can get a wonderful "HD" one from you guys with some of these problems sorted out
Ouch ... I bet! Do you refund the core charge pro-rata depending on what weight of gearbox is left? ![]() I remember a vehicle coming in to our workshop years ago, didn't look like that but the prop UJ had let go at about 50mph and the driver's footwell was touching the bottom of the pedals. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Phantom Member Since: 29 Jan 2013 Location: Isle of Wight Posts: 136 ![]() ![]() |
I run a independent LR specialist workshop, having owned and repaired pretty much every defender variant going I’d always personally choose a Tdi or td5 over a tdci - every time. We see more mechanical issues with the pumas than all the other defenders put together. |
