![]() | Home > Tdi > LT77 tunnel clearance with R380 |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
You may have to use a bulkhead diaphragm
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Given that the LT77 and R380 are basically the same gearbox there shouldn't be any problems It is not a Defender, it is a One_Ten
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
The bell housing of the 300 tdi r380 is considerably larger than that of the lt77. Is this why the tunnel size was increased?
Whilst the gearbox remained in the same location, when the 300 was introduced the engine was moved forward 8 inches, hence the longer bell housing. Plus the R380 has a longer input shaft.
There is a short bell housing available for the R380 to enable its fitment with alternative diesel engines, presumably with a shorter input shaft It is not a Defender, it is a One_Ten |
