Home > In Car Electronics > Trying to understand my Puma wiring - upgrading sound
Page 2 of 2 <12
Stacey007
What did Urban charge also... Rolling with laughter
As for the Focal Sub, does it come with a remote (wired or not) to turn the base up / down.
I'm considering this, but used to have Rockford Fosgate stuff back in my teenage days with dedicated amps and the like.... do I want to go down the rewire road.... Shocked
Thumbs Up
Post #763177 13th Mar 2019 1:03pm
Juanplatano
Switzerland 2012 Defender 110 Puma 2.4 Black LE Java Black
Farmerben wrote:
It's all done!
Pioneer z7100 Flip out head unit
Focal ES100K kit in the front
Focal PC130 in the back (mounted in Mud rear speaker panels)
Alpine SWE1200LR mounted to back of sub.
Mic for bluetooth mounted on top of A pillar trim
All working and sounding un-freaking-believable.
Thanks to everyone for the help.
Thumbs Up
Hey mate, how did you get the sub to work? I have just bought a pioneer Z7100 and having the same issue... cheers
Post #766460 1st Apr 2019 9:49pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Did you buy the LR040847 link harness?
Mine also needed a power feed wired in which I got a local auto electrical guy to do for me. https://instagram.com/bentheoandrews
Post #766474 2nd Apr 2019 7:34am
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
Can you confirm how long the LR040847 harness is? I can see it connects to the RCA plugs on the back of the Alpine head unit but does it run behind the dash and under the cubby to the sub?
Many thanks Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #766520 2nd Apr 2019 1:33pm
Martin
Site Admin
I believe it’s only short and is just an adapter between the phonos and a multiplug.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #766526 2nd Apr 2019 1:55pm
Ihod
Thanks, Martin - I thought so.....so there's another part or this part works in conjunction with a vehicle that was pre-wired for the sub?
Mine wasn't, so - assuming the latter - I'm better off sticking with making my own loom? Ian
Post #766531 2nd Apr 2019 2:23pm
Juanplatano
Exaclty! Just bought the cable adapter. Lets see.
Was your sub/pioneer stereo OEM ? I wonder if I will have to take it to an electrician or whether the adapter will do the magic
Post #766537 2nd Apr 2019 3:37pm
Juanplatano
Many thanks
It does not matter if long or short, its just a cable to convert the 16 PIn into ISO. You want it short
Post #766539 2nd Apr 2019 3:41pm
Martin
Site Admin
LR040847 isn’t enough on its own to retrofit the sub.
The power supply, switch-on wire and ground also need adding.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #766540 2nd Apr 2019 3:45pm
Farmerben
Was your sub/pioneer stereo OEM ? I wonder if I will have to take it to an electrician or whether the adaptor will do the magic
My sub was a genuine Land Rover Alpine sub. I had the plug under the cubby that connected straight into the sub then used the harness to go from the other end that was loose behind the dash to the back of the head unit. The only thing missing was a power supply which someone fitted for me. https://instagram.com/bentheoandrews
Post #766564 2nd Apr 2019 5:37pm
Juanplatano
Thank you mate!
Post #766674 3rd Apr 2019 4:41pm
Page 2 of 2 <12
