![]() | Home > In Car Electronics > Trying to understand my Puma wiring - upgrading sound |
Juanplatano Member Since: 01 Apr 2019 Location: Zurich Posts: 10 ![]() ![]() ![]() |
Hey mate, how did you get the sub to work? I have just bought a pioneer Z7100 and having the same issue... cheers |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 ![]() ![]() ![]() |
Did you buy the LR040847 link harness?
Mine also needed a power feed wired in which I got a local auto electrical guy to do for me. https://instagram.com/bentheoandrews |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 ![]() ![]() ![]() |
Can you confirm how long the LR040847 harness is? I can see it connects to the RCA plugs on the back of the Alpine head unit but does it run behind the dash and under the cubby to the sub?
Many thanks Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
I believe it’s only short and is just an adapter between the phonos and a multiplug.
Thanks, Martin - I thought so.....so there's another part or this part works in conjunction with a vehicle that was pre-wired for the sub?
Mine wasn't, so - assuming the latter - I'm better off sticking with making my own loom? Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
Exaclty! Just bought the cable adapter. Lets see.
Was your sub/pioneer stereo OEM ? I wonder if I will have to take it to an electrician or whether the adapter will do the magic |
It does not matter if long or short, its just a cable to convert the 16 PIn into ISO. You want it short |
LR040847 isn’t enough on its own to retrofit the sub.
The power supply, switch-on wire and ground also need adding. ![]() ![]() |
My sub was a genuine Land Rover Alpine sub. I had the plug under the cubby that connected straight into the sub then used the harness to go from the other end that was loose behind the dash to the back of the head unit. The only thing missing was a power supply which someone fitted for me. https://instagram.com/bentheoandrews |
Thank you mate!
