Home > Puma (Tdci) > Wiring diagram Puma 2009 /
Harald
Belgium 2010 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
Today I had a closer look at the three connectors on the ECU.
Connector C0411 is the first (upper) one.
Connector C2518 is the third (lowest) one.
Picture is from LR Defender Electrical Connector Manual.
But....if you look at the cable colours you will see that in reality C0411 and C2518 are switched.
When you look under the bonnet you will see that the wiring from the VGT (C21519-1 & C2519-2) go straight to the upper ECU connector, not the third (lowest) one.
Did anybody also noticed that?
Post #750682 12th Jan 2019 10:24am
dorsetsmith
wiring diagram changed I.E. 07 to 09 starter motor is control by ECM post this vin starter motor is control by As10
and so on also (C21518-1 & C2518-2) Whistle
Post #750696 12th Jan 2019 11:26am
Harald
I have an VIN: 751063 > version and a VIN: 732615 - 751062 version.
Thought the 751063 was OK for my car.
My VIN = 784***.
Both ECU wiring diagrams are the same, as far as I can see.
If these diagrams are not correct, could I find the correct one somewhere online, or does someone have the correct ECU wiring diagram?
Post #750699 12th Jan 2019 12:21pm
Harald
Post #751162 14th Jan 2019 10:05am
