Home > Puma (Tdci) > Wiring diagram Puma 2009 / |
When you look under the bonnet you will see that the wiring from the VGT (C21519-1 & C2519-2) go straight to the upper ECU connector, not the third (lowest) one.
wiring diagram changed I.E. 07 to 09 starter motor is control by ECM post this vin starter motor is control by As10 and so on also (C21518-1 & C2518-2) |
12th Jan 2019 11:26am |
Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81 |
I have an VIN: 751063 > version and a VIN: 732615 - 751062 version.
Thought the 751063 was OK for my car. My VIN = 784***. Both ECU wiring diagrams are the same, as far as I can see. If these diagrams are not correct, could I find the correct one somewhere online, or does someone have the correct ECU wiring diagram? |
12th Jan 2019 12:21pm |
14th Jan 2019 10:05am |
