Home > Off Topic > LandRover Related Injuries |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Just a heads up.....keep your feet well away from a Transfer Box when you are lifting it out of the way.
Click image to enlarge |
4th Mar 2019 10:14am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20477 |
Watch you donโt bash your head on an open door if you get under it and back out. No Guts, No Glory.
๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
4th Mar 2019 10:34am |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Well I will go with mine.... It was not because I was working on the defender but it was that I was going to transport a few sheets of
1mm stainless steel. The problem, apart from me, is that the dorr of my 110 is small, like all the defenders, so in order to fit said sheets i will have to bend them, ans then release them inside..... Well they never reach inside, i got trapped between the sheets and the door and as they unfold they cut clean the skin on my forearm and the tendons and the arteries and nerves of my right hand. I could not drive anything for 3 months and still, after 2 years all the movement has not been restored. Have fun, wear long sleeves, be save Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
5th Mar 2019 9:35pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
that sound bad.
when I changed my diff on axles stands, i was struggling to lift it back into the axle, it slipped off the jack and onto my shoulder, it has hurt to lift anything above head height ever since, only started to ease off after about 6 months DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
6th Mar 2019 6:23am |
