Home > Off Topic > LandRover Related Injuries
Page 2 of 2 <12
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Having worked in industry and latterly at a heritage railway I have had it drummed into me to wear the appropriate P.P.E.
So its bump stop hat, eye protection, steel toe cab boots, overall's and gloves for any work on the land rover so that I'm all safe except onetime having laid underneath a 300TDi to sort out an earthing problem which I sorted out went into the garage to rid myself of the P.P.E. and stepping out of the boots I put me left foot down without looking straight on the an upturned 3 pin plug which resulted in two broken bones in said foot and six weeks with foot in plaster. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #750689 12th Jan 2019 10:50am
smb
Just a heads up.....keep your feet well away from a Transfer Box when you are lifting it out of the way. Rolling Eyes
Post #761832 4th Mar 2019 10:14am
Watch you donโ€™t bash your head on an open door if you get under it and back out. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #761838 4th Mar 2019 10:34am
ajps72
2001 Defender 110 Td5 SW Chawton White
Well I will go with mine.... It was not because I was working on the defender but it was that I was going to transport a few sheets of
1mm stainless steel.
The problem, apart from me, is that the dorr of my 110 is small, like all the defenders, so in order to fit said sheets i will have to bend them, ans then release them inside..... Well they never reach inside, i got trapped between the sheets and the door and as they unfold they cut clean the skin on my forearm and the tendons and the arteries and nerves of my right hand.
I could not drive anything for 3 months and still, after 2 years all the movement has not been restored.
Have fun, wear long sleeves, be save Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #762099 5th Mar 2019 9:35pm
LR90XS2011
that sound bad.
when I changed my diff on axles stands, i was struggling to lift it back into the axle, it slipped off the jack and onto my shoulder, it has hurt to lift anything above head height ever since, only started to ease off after about 6 months DEFENDER 90 TDCI XS,
Post #762120 6th Mar 2019 6:23am
Page 2 of 2 <12
