Home > Wheels & Tyres > Bowler Spare Wheel
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Bowler Spare Wheel
Just ordered a bowler wheel 18inch for my spare. Will be on BFG 285/60/18 tire. Just wondering does it fit the original spare wheel holder or do I need spaced or any mods to have it fit? Also with the rear door opened will it hit the lights? Thanks.
Post #750167 9th Jan 2019 2:57pm
JOW240725
I don't think you'll have any issues. I have 16" Bowler with very similar tyre diameter with no issues. I believe the 18" are ET15 compared to 16" being ET10 but sure it will be OK.
You might want a spare wheel lock of Brendan Whistle James
Instagram @suffolk_rovers
Post #750170 9th Jan 2019 3:30pm
Michaelkan
Spare wheel lock of Brendan? I’m thinking using a chain lock over it. Although I seen a padlock for spare wheel on a defender. Really neat looking lock. Anyone got a recommendation of locks? Thanks.
Post #750174 9th Jan 2019 3:40pm
Michaelkan
One that similar to this that fit bowler wheels?
Post #750176 9th Jan 2019 3:49pm
JOW240725
Sorry... off Brendan the forum sponsor from 4x4overlander https://www.4x4overlander.com/product/defe...protector/
I used a soft bike lock temporarily but it wore a tiny dink in the paint Big Cry
The padlock type you mention, if it's the one I'm thinking of won't fit the Bowlers. James
Post #750177 9th Jan 2019 3:51pm
pjrb
Wherebouts did you buy the spare wheel?
Post #750195 9th Jan 2019 6:56pm
Michaelkan
eBay.
Post #750197 9th Jan 2019 7:05pm
LR Sam
from my experience 285's will hit the lights on opening the door fully. I added a spare wheel carrier (mantec) and this stopped the lights hitting issue. They were ET0 wheels
Post #750237 9th Jan 2019 9:27pm
Michaelkan
Damn. You are right. It hit the lights when fully opened. So what are my options? Does Mantec swing away solve the problem? Can anyone confirm pls? Thanks.
Post #750328 10th Jan 2019 3:31pm
Michaelkan
And do I need to get the adapter longer bolt for 285 wheels. Thanks.
Post #750349 10th Jan 2019 4:54pm
LR Sam
The mantec sorted it for me as the wheel is bolted in a slightly different position and the arm effectively stops it. I think Mantec have gone bust though but hopefully someone should be able to tell you.
Post #750355 10th Jan 2019 5:10pm
Michaelkan
Mantec still around. I think flatdog carries them.
Post #750382 10th Jan 2019 6:41pm
TJ101
18" Bowler on the rear
I can't remember if it hit the lights or not,, Did not think it did,,But i want with a Mantec carrier, mainly to sves the door hinges
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #750414 10th Jan 2019 9:19pm
Michaelkan
Ordered a mantec swingaway with spacer and longer bolts. Should be sorted as long I don’t messed up with the drilling of the holes.
Post #750419 10th Jan 2019 9:28pm
Michaelkan
Finally managed to fit the bowler as a spare. For those that using mantec swingaway army version, u will need the extension and the spacer. The wheel doesn’t touch the inductor.
Post #754521 28th Jan 2019 4:13pm
