![]() | Home > Wheels & Tyres > Bowler Spare Wheel |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
I don't think you'll have any issues. I have 16" Bowler with very similar tyre diameter with no issues. I believe the 18" are ET15 compared to 16" being ET10 but sure it will be OK.
You might want a spare wheel lock of Brendan ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 ![]() ![]() ![]() |
Spare wheel lock of Brendan? I’m thinking using a chain lock over it. Although I seen a padlock for spare wheel on a defender. Really neat looking lock. Anyone got a recommendation of locks? Thanks.
One that similar to this that fit bowler wheels?
Sorry... off Brendan the forum sponsor from 4x4overlander https://www.4x4overlander.com/product/defe...protector/
I used a soft bike lock temporarily but it wore a tiny dink in the paint ![]() The padlock type you mention, if it's the one I'm thinking of won't fit the Bowlers. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
pjrb Member Since: 12 Sep 2018 Location: London Posts: 27 ![]() ![]() |
Wherebouts did you buy the spare wheel?
eBay.
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 235 ![]() ![]() |
from my experience 285's will hit the lights on opening the door fully. I added a spare wheel carrier (mantec) and this stopped the lights hitting issue. They were ET0 wheels
Damn. You are right. It hit the lights when fully opened. So what are my options? Does Mantec swing away solve the problem? Can anyone confirm pls? Thanks.
And do I need to get the adapter longer bolt for 285 wheels. Thanks.
The mantec sorted it for me as the wheel is bolted in a slightly different position and the arm effectively stops it. I think Mantec have gone bust though but hopefully someone should be able to tell you.
Cheers |
Mantec still around. I think flatdog carries them.
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
18" Bowler on the rear
![]() Click image to enlarge I can't remember if it hit the lights or not,, Did not think it did,,But i want with a Mantec carrier, mainly to sves the door hinges ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Ordered a mantec swingaway with spacer and longer bolts. Should be sorted as long I don’t messed up with the drilling of the holes.
Finally managed to fit the bowler as a spare. For those that using mantec swingaway army version, u will need the extension and the spacer. The wheel doesn’t touch the inductor.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
