Home > Td5 > swivel housing bearing pre-load
kevinf
some technical info required
had to replace the o/s swivel housing bearings on my sept 2002 td5 after the top one collapsed,but unfortunately didnt have access to a spring balance(even the local angling shop had sold out) and had to continue to build up the axle, needed the vehicle for work etc.
now i,ve bought a spring balance just wondered if any body has a pre-load figure for the swivel housing now it fully assembled i.e seal fitted full of one shot grease etc,so i can check it and if necessary adjust it?
cheers kevin
Post #70200 8th May 2011 8:37pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
HI If you send me a PM with your email I will send you the workshop manual it will be in there somewhere Thumbs Up
Post #70324 9th May 2011 9:03pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
The workshop manual gives the figures for the swivel without seal and grease which is why i think hes asking. I cant remember what it is fully built but there is a figure somewhere as ive seen it before.
Pete.
Post #70339 9th May 2011 10:06pm
Naks
Anyone know what the preload on a 2010 Puma 90 should be? thanks! --
Post #80958 19th Jul 2011 10:44am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Im thinking of overhauling the swivels and cv joints on my defender this weekend.
Anyone recomend a decent brand to fit, loads of Britpart kits out there, strugling to find anything else.
Famous four have some kits on there web site but no details on manufaturer.
Post #80961 19th Jul 2011 11:49am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Without it was something like 4kgs of pull,
With it varies on the quality of the seal and the grease. 2002 Defender 110 DC
Post #80964 19th Jul 2011 12:10pm
Paul_1978
Rave says 1.16 to 1.46kg of pull.
This is without seals and grease.
Post #80965 19th Jul 2011 12:17pm
ben_j85jty
Shows that my memory is fading faster than I thought!
I remember it being a very dirty, horrible job and taking a good while to get right. Even now I am not entirely sure it's right. 2002 Defender 110 DC
Post #80978 19th Jul 2011 1:52pm
