Home > Puma (Tdci) > Dashboard slowly gone dark
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi
I’m in the middle of a double din headunit install and thought I’d replace the dead instrument bulbs at the same time as the dash has got progressively darker over the last year or so.
But .. what are these bulbs and where can I get them?
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #747397 26th Dec 2018 3:44pm
dorsetsmith
Capless bulb 1.2 watt 12 volt
RTC3635
land rove , Halford,
Lucas 286 12V 1.2W Minature Bulb
Post #747400 26th Dec 2018 4:02pm
carrotbay
Great .. thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #747407 26th Dec 2018 4:43pm
stumanuk42
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
How easy are these to get at, as one of mine has gone out?
Post #750065 8th Jan 2019 8:18pm
carrotbay
Really easy .. undo the 2 star bolts on the dash panel and pull it off (there are 6 or 8 clips that will pull out). You should be able to move it out enough with all switches connected and radio installed. You can then just pull the little bulbs out of their holders and replace them 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #750085 8th Jan 2019 9:06pm
