Home > Maintenance & Modifications > Sorting leaks around body seals
turnah
United Kingdom 2005 Defender 90 Td5 HT Belize Green
Hi all, first post so a wee introduction at the same time.
Traded in my sensible car and picked up my first defender, a TD5 hardtop 90 a couple of months ago and have been stalking, picking up tips ever since.
So far I've had the security sorted out by someone who knows what he's doing and I've fitted the clutch mod, rear reverse camera, replaced the switches for courtesy lights so they work and added a new radio.
Lots more on my to-do list with an engine remap in the new year, vw 90 wiper switch mod, fix sticking wipers, new cubby box, slick shift and sound deadening on the list as the pay packets come in.
My knowledge of cars is zero, but I've bought a socket set and love tinkering and understanding how and why things work so hopefully this will keep me happy.
One thing I want to do over the Christmas break is sort out a couple of leaks, so I've got myself some sikaflex to sort the roof joins and gutters which is where I've identified the majority of the water is coming from (and ending up on my passengers knees).
My question: Water is also appearing from the seals around where the tub meets the body at the back and sides. What's the best thing to do with these? It looks like the foam is twisted on one of the leak areas and a wee bit perished in a few other places - both areas behind the back speakers are affected by the trickles which has rendered them inoperative so before buying some new speakers want to nip this in the bud.
From what I gather I could lift the shell and replace the seal, or some people have mentioned to fill with sikaflex over the seals. If doing the later would it be a pain if it had to come off at a later date for work? I was thinking of picking some up in black and filling in the gaps neatly and painting at a later date if it doesn't look right.
I've got a copy of the ingress manual and these two areas seem to be my only problem, but I'll be sealing other bits I get access to them to be safe.
Just want to treat it with respect and do things right rather than take any shortcuts so any advice would be appreciated! Any better methods would be welcome!
Thanks,
Michael
Post #746675 20th Dec 2018 11:20pm
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
A cause of water ingress into the footwells is sometimes due to the water running off the gutter that runs below the windscreen under the bonnet and down the bulkhead inside the engine compartment. On the passenger side, this then seeps through the heater box to bulkhead seal and into the footwell. On the driver side, it would leak through the many access holes on the bulkhead.
It is called a Fender seal pt no LR 038612 price £10.21 inc Vat. I found the cheapest supplier was Land Rover themselves. It is the same part no for both n/s and o/s
It is very easy to fit and just pushes onto the wing flange inside the engine bay up against the bulkhead. I will try and post a picture later on
I would also recommend you go to this site as it is a great resource for locating part numbers and seeing exploded diagrams of all the assemblies. http://www.landroverworkshop.com/
Also I do have a spare copy of the Rave Disc (Full Land Rover workshop manual) Td5 and older models if you want it
Post #746708 21st Dec 2018 9:55am
donmacn
Hi Michael - welcome to Defender ownership and the forum - an invaluable amount of information an help on here.
Dave, would definitely appreciate a picture. This is the first I've heard of these. I've found an online pic of them on an Australian site, but in their packets rather than on the car. I think I understand exactly what you've said, but a picture would be good.
D
Edited to say: Michael - there's a couple of pics on my thread, linked below, to show how I put a bead of sealant between the sides and the tub. Not my original idea though, just something I picked up elsewhere.
I'd suggest new seals first, depending on the age of the car. I put sealant in because I know my seals were (relatively) new and obviously just needed some more help. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #746716 21st Dec 2018 10:18am
foggydave
Pictures as promised. The weather being appropriate to the subject
I used gutter sealer (because its black) to seal the fender against bulkhead as it still dripped a bit.
Post #746733 21st Dec 2018 1:11pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
If you could post a pic of that it would be great. As I was thinking of putting a old mudflap on the bulkhead! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #746734 21st Dec 2018 1:20pm
gazman
Thanks that man!! You did that whilst I was doing my reply! 2014 - current ..... 2003 defender td5 90 (my car)
Post #746735 21st Dec 2018 1:21pm
frenchy
These look great!!!
Seems places are low on stock....has anyone been able to locate any? 2000 D2 TD5 - ahhh bless
2006 D3 - no longer with us and sadly missed
1997 300tdi d90 - now with electrics that work!
- now with a brand new custom made soft top fitted
…...…...............….new chassis now all fixed and driving like new
2010 D4 alas no more, but a lovely colour (Nara)
2016 D4 battery magically fixed with NOCO charger
Post #746739 21st Dec 2018 1:41pm
donmacn
As above, thanks Dave. If they'll contribute to minimising leaks etc, then they do look pretty good. Donald
in the past..
Post #746744 21st Dec 2018 2:26pm
foggydave
I live in Leicester so go to Sturgesses the main LR dealer. I bought one for the o/s last week. They got it in next day. As I said these were cheaper than buying from another supplier online. So go to your main LR dealer and they should be able to get one.
Post #746749 21st Dec 2018 2:56pm
turnah
That's fantastic, I've just ordered a couple from Landrover Stockport - factory order but will be in to collect by 9am tomorrow at he same price you quoted. Every little helps!
As for the back I think I'll wait for the weather to improve and have a go at replacing the seals as they don't seem too pricey and see how i get on with the drips.
Post #746767 21st Dec 2018 4:25pm
oneten110
Reading this might save you some time and money.
https://www.defender2.net/forum/topic7178.html
Post #747069 23rd Dec 2018 6:20pm
Yatesy
United Kingdom 2011 Defender 90 Puma 2.4 HT Zambezi Silver
Just ordered these myself, have they solved the footwell issue?
Post #748674 2nd Jan 2019 12:40pm
foggydave
Worked a treat for me. Now perfectly dry. I did though put a run of bitumen gutter sealer between fender and bulkhead.
Note If it still leaks after fitting fender.
When fitting the fender the water which went straight into the engine bay is now flowing over the joint between the wing top and the bulkhead and could go into the driver's side footwell through a fixing hole or the grommet where the door electrics route if there is a gap in this joint.
Post #748688 2nd Jan 2019 1:56pm
turnah
I'm all dry up front too now, but I've sealed the roof and gutters as well as installing these so could be a bit of both helping.
Post #748690 2nd Jan 2019 1:59pm
Adammacky
Anyone know where you can still get these fender seals? Links would be awesome!
Post #826275 18th Apr 2020 8:33pm
