![]() | Home > Maintenance & Modifications > Sorting leaks around body seals |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 ![]() ![]() ![]() |
A cause of water ingress into the footwells is sometimes due to the water running off the gutter that runs below the windscreen under the bonnet and down the bulkhead inside the engine compartment. On the passenger side, this then seeps through the heater box to bulkhead seal and into the footwell. On the driver side, it would leak through the many access holes on the bulkhead.
It is called a Fender seal pt no LR 038612 price £10.21 inc Vat. I found the cheapest supplier was Land Rover themselves. It is the same part no for both n/s and o/s It is very easy to fit and just pushes onto the wing flange inside the engine bay up against the bulkhead. I will try and post a picture later on I would also recommend you go to this site as it is a great resource for locating part numbers and seeing exploded diagrams of all the assemblies. http://www.landroverworkshop.com/ Also I do have a spare copy of the Rave Disc (Full Land Rover workshop manual) Td5 and older models if you want it Last edited by foggydave on 21st Dec 2018 12:13pm. Edited 1 time in total |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
Hi Michael - welcome to Defender ownership and the forum - an invaluable amount of information an help on here.
Dave, would definitely appreciate a picture. This is the first I've heard of these. I've found an online pic of them on an Australian site, but in their packets rather than on the car. I think I understand exactly what you've said, but a picture would be good. Cheers D Edited to say: Michael - there's a couple of pics on my thread, linked below, to show how I put a bead of sealant between the sides and the tub. Not my original idea though, just something I picked up elsewhere. I'd suggest new seals first, depending on the age of the car. I put sealant in because I know my seals were (relatively) new and obviously just needed some more help. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Pictures as promised. The weather being appropriate to the subject
I used gutter sealer (because its black) to seal the fender against bulkhead as it still dripped a bit. ![]() Click image to enlarge ![]() Click image to enlarge |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
If you could post a pic of that it would be great. As I was thinking of putting a old mudflap on the bulkhead! 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
Thanks that man!! You did that whilst I was doing my reply! 2014 - current ..... 2003 defender td5 90 (my car)
frenchy Member Since: 05 Feb 2012 Location: Liverpool Posts: 133 ![]() |
These look great!!!
Seems places are low on stock....has anyone been able to locate any? 2000 D2 TD5 - ahhh bless 2006 D3 - no longer with us and sadly missed 1997 300tdi d90 - now with electrics that work! - now with a brand new custom made soft top fitted …...…...............….new chassis now all fixed and driving like new 2010 D4 alas no more, but a lovely colour (Nara) 2016 D4 battery magically fixed with NOCO charger |
As above, thanks Dave. If they'll contribute to minimising leaks etc, then they do look pretty good. Donald
I live in Leicester so go to Sturgesses the main LR dealer. I bought one for the o/s last week. They got it in next day. As I said these were cheaper than buying from another supplier online. So go to your main LR dealer and they should be able to get one.
turnah Member Since: 30 Sep 2018 Location: Lancashire Posts: 40 ![]() ![]() ![]() |
That's fantastic, I've just ordered a couple from Landrover Stockport - factory order but will be in to collect by 9am tomorrow at he same price you quoted. Every little helps!
As for the back I think I'll wait for the weather to improve and have a go at replacing the seals as they don't seem too pricey and see how i get on with the drips. |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
Reading this might save you some time and money.
https://www.defender2.net/forum/topic7178.html |
Yatesy Member Since: 19 Jul 2018 Location: North West Posts: 72 ![]() ![]() ![]() |
Just ordered these myself, have they solved the footwell issue?
Worked a treat for me. Now perfectly dry. I did though put a run of bitumen gutter sealer between fender and bulkhead.
Note If it still leaks after fitting fender. When fitting the fender the water which went straight into the engine bay is now flowing over the joint between the wing top and the bulkhead and could go into the driver's side footwell through a fixing hole or the grommet where the door electrics route if there is a gap in this joint. Last edited by foggydave on 2nd Jan 2019 1:02pm. Edited 1 time in total |
I'm all dry up front too now, but I've sealed the roof and gutters as well as installing these so could be a bit of both helping.
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
Anyone know where you can still get these fender seals? Links would be awesome!
