Home > Tdi > Steering hardens when driving through water
Huttopia
On my 96 300tdi, if I drive through a bit of flooded lane or a large puddle that splashes up, the steering becomes heavy momentarily, it is as if the power steering cuts for a moment.
Any ideas?!
Many thanks,
Huttopia
Post #746355 18th Dec 2018 9:28pm
LR90XS2011
could be a wet belt = slipping belt? hence power steering not working, check belt condition and adjustment DEFENDER 90 TDCI XS,
Post #746357 18th Dec 2018 9:32pm
seriesonenut
It will be the belt slipping. Not sure you can adjust it out TBH. It has happened to me a few times in the past but it soon returns to normal. 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #746358 18th Dec 2018 9:40pm
grafty99
+1 for auxiliary belt slipping Thumbs Up
I'd imagine in the dark your headlights would dim slightly as the alternator slows too 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #746362 18th Dec 2018 10:19pm
Huttopia
Thanks all, that makes sense. I’ll have a look at the weekend Thumbs Up
Post #746376 19th Dec 2018 5:48am
oneten110
Given that it is a serpentine belt, adjustment is likely to prove difficult. Replacement might help obviate the problem.
Post #746378 19th Dec 2018 7:33am
jst
It's the belt. I would have it off, check condition and probably replace tensioner. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746379 19th Dec 2018 7:41am
Huttopia
I need to check but I think it had a new tensioner about 18 months ago!
Post #746381 19th Dec 2018 8:17am
ARC99
Do the Tdi's have the same problem as the 300 Tdi's with the serpentine belt were the tensioner was putting a load on the belt, slowing it down, as well as cutting into it. Don't make old people mad.
Richard
Post #746389 19th Dec 2018 9:36am
jst
^^^ i have not heard of that one before. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746561 20th Dec 2018 8:09am
jst
How much was the tensioner? if cheaper one it may have failed, check belt, change if looking suspect then consider tensioner.
How deep water are we talking about? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746562 20th Dec 2018 8:10am
dailysleaze
My power steering doesn't work for the first 10 seconds sometimes due to heavy condensation
Post #746574 20th Dec 2018 9:57am
yostumpy
Mine does it as well
Post #746597 20th Dec 2018 12:46pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
To check your belt wear /stretch , there are 2 marks on the tensioner one the sprung load part, and one on the fixed part, when these line up, its time to renew the belt, [ 300 tdi"s]
Post #746648 20th Dec 2018 7:14pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
My old 19J used to do it, i put it down to another Landy quirk
Post #746686 20th Dec 2018 10:56pm
