Home > Maintenance & Modifications > The security question again
AndrewS
I've go a 110 utility coming this Thursday and wont be able to lock it away as I can with my other Defenders. So I am going to fit security. I have searched on here and can see that over time security devices are not as secure as they once were, for example the availability of battery disc cutters have rendered some items virtually worthless. So im after up-to-date advice if anyone can help that would be great.
I'm going to point out some items and place my comments/perception against them. Please feel free to add your items or correct mine.
Pedal Locks:- Positive = Vehicle cant be driven away whilst fitted. Negative= Wont stop the vehicle being loaded onto a trailer? can be cut off.
Steering locks:- Positive = Visual Deterrent. Negative= If the thief opens the door the steering wheel can be turned?
Removable steering wheel with boss lock:- Positive = Cant steer the vehicle, Negative = ??? Please comment
Tracker:- Seems a good idea to get your car back if it gets nicked, I dont want it to get nicked in the first place.
Gear lever lock:- Positive = Impossible to move vehicle. Negative = Can be cut off, no use if props are removed, *not available for Puma Defenders.
Clearly there are all the other handy bits ref bonnet cable guard, critical alarm loom relocation, isolator switch etc etc
The thing is there doesn't seem to be anything on the market you can fit and have a good nights sleep knowing that the vehicle will be safe. As I have mentioned above the removable steering wheel with the boss lock seems the best starting point. What do youse think?
* Edit 130's have feeling's as well you know Smile
Post #746220 17th Dec 2018 10:13pm
Sulisuli
I have the pedal lock and removalable steering wheel with boss lock and I’m happy, quick to fit, offers some peace of mind without being a PIA to use and I drive mine everyday so need something functional without being awkward to fit, hope this helps Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #746230 17th Dec 2018 10:48pm
Dobby
Or.... just spend the money on a better insurance policy, with an agreed value. Rather than a bargain basement online policy that’ll shaft you in the event.
Much better for your blood pressure than having to constantly worry about all your security heels and whistles. There’s money in the fear that is peddled about car thievery.
As the old adage goes, if they want it they’ll take it.
Post #746233 17th Dec 2018 11:10pm
AndrewS
I have a very good 'fleet' policy Thumbs Up all the vehicles with modifications and extras are recorded and kept upto date and photographs sent to my broker. So I'm not worried about the loss, its the hassle of the theft I'm trying to avoid. Thumbs Up Thumbs Up 130's have feeling's as well you know Smile
Post #746243 17th Dec 2018 11:41pm
jst
X~eng ignition lock as another layer. Stops std steering lock being broken off. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746250 18th Dec 2018 6:53am
jst
Hydraulic lock system Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746254 18th Dec 2018 6:57am
AndrewS
What's one on those ? 130's have feeling's as well you know Smile
Post #746257 18th Dec 2018 7:10am
OsloBlue
I would say ditch the factory immobiliser and alarm system. They can’t defeat what they don’t expect.
Eventually going to get rid of the disklok for a optimil QD hub lock... seems like less hassle.
Interested in those mech locks... anyone have one?
I think this whole hiab stuff is misunderstood, I think it’s tow trucks with winches rather than rigids with cranes. So you should be able to defeat them by parking in gear...
Also a good tracker is better than physical security. It will lower your premiums and the leading two products (tracker, Automatrics & defender defender) all have vibration monitors that text you when your vehicle has been moved.
Last month I drove somewhere at 4am without disabling the system and got a call from my tracking company.
“Hi, Mr Osloblue I’m calling from your tracking company, sorry to wake you, but we’re calling you to let you know your car has been stolen, but not to worry we’re tracking it and in the process of informing the police” the lady said smugly
I had to inform her that I was still in possession of my car and driving it in fact... I'm on IG: https://www.instagram.com/osloblue42/
Post #746261 18th Dec 2018 7:28am
jst
https://www.landroverdefendersecurity.com/...-mechanism
Not necessarily that one but you get the idea, brake or clutch system. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746262 18th Dec 2018 7:32am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I tried everything and I mean everything. All I found was they kept coming back and probing to see what security I had.
What stopped it literally over night was a 2nd alarm with a warn away sounder. I still have the normal landrover one, but it is modified.
It wouldnt work if you had to park over night on a road as it would chirp constantly, but it's that good my mate went out and got one on his too. I park mine on the drive and I've even forgotten on occasion to remove the steering wheel, pedal lock and even lock it but it's been left alone!
I have trackers too that alarm with the alarm and start signalling me. I really dont worry about it anymore.wouldnt leave it anywhere dodgy though 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #746263 18th Dec 2018 7:36am
leeds
Defenders locked up out of sight in a monitored alarm building is probably one of the best preventive measures. Not always possible.
Many of the possible measures have already been mentioned.
Now some thieves overcome alarm etc and then push vehicle onto road etc. If wheels are in a trough then it will be difficult to push the vehicle away.
A big chain from recovery point to a solid ground anchor?
A monitored alarm on the drive or yard? No good if postman etc walks up drive.
Brendan
Post #746273 18th Dec 2018 9:17am
barbel jim
Unfortunately prevention is always behind and out dated, and new options are good until defeated......which they invariably are Rolling Eyes Having been on the receiving end a few years ago of an armed break in for the keys, I find the best approach is multi layers........ Visible will deter some, and hidden will then slow down the process. Your hoping they will give up and find an easier target. Trackers are good as long as its not in an obvious place, and you genuinely want the vehicle back. I've put up CCTV at home, more as a deterrent, but if it did happened to aid prosecution. Its surprisingly affordable and excellent quality.
Post #746280 18th Dec 2018 11:24am
camelman
If it's one of the later Pumas this won't fit, only works up to MY 2014
Post #746281 18th Dec 2018 11:25am
X4SKP
Re: The security question again
Hello AndrewS
If I were forced to have just one security measure then this would be it...Nothing is 100% but armed with several additional layers, this IMO is a very good measure...(I really don't understand why it isn't used more often).
Negatives... Not many IMO, you either have to get back to the Spline and a good Boss Lock and Security Fixings (or in my case something custom) can make this time consuming, and then carry a spare Steering Wheel (of the correct type) to get you past this measure.
Or some systems can be jammed with a screw driver or gripped with a G Clamp to gain enough purchase to steer away, but there are ways to minimise this 'failing'.
For Vehicles parked in the same place then coming prepared can be planned for but for random parking and being confronted with this for the first time, it's a strong physical and visual message.
I agree...last resort, but have one (or two)
Also...
X Defend
https://foundry4x4.co.uk/pdf/X%20Eng%20at%...ctions.pdf
Security Marking
http://www.retainagroup.com/
BBS
I have a few of these fitted, both externally and internally. Not the standard LR BBS (Battery Back Up Siren) but an alternative. When triggered it is difficult to stay in the Vehicle Shocked
Good Luck. SKIP
Post #746287 18th Dec 2018 12:07pm
Dobby
Fairy nuff. Very Happy
In that case.. if you can/want--do some or all of these things depending on how much you want to spend.. But you're right a battery cutter/whizzer is your main enemy.
1. Keep it in a garage when not in use.
2. Aim for the holy-trinity of add-ons. i.e. Pedal lock, Steering lock, gear lock.
3. Put Liquid metal in all your door fixings to stop door removal. You can buy posh hinges too, but LM is just as good.
4. Bike cable and padlock the bonnet to the engine. Posh hinges also available if you want. Be careful not to get the padlock in such a position that it sits on the top of the engine, otherwise you'll dent your bonnet when you close it.
5. Battery loom bypass. One of the main weaknesses is the battery loom being accessible underneath the vehicle, so can be easily cut to disable the alarm/locks. The bypass re-routes the power inside the cab instead. Leave original, but dead, loom in place.
6. BBUS for the alarm and relocate it away from the behind the headlamp location. And/Or drill out/liquid metal all the headlamp fixing screw heads.
7. Pedal locks, generally good but be aware of the weaknesses. Get one that covers the pedal arms too, otherwise they cut the arms and drive on the stumps. Make sure it covers all the pedals too, not just the brake.
8. Steering locks good. If you go for disklok get it modified to ensure it can't be 'peeled' off. Don't get one that can be removed by simply cutting through the steering wheel. Leave parked on full-lock
9. Steering locks #2. If you can/want weld on your drop-arm bolts. Steering locks are easily defeated by removing the bolt on the steering linkages so the vehicle can be towed away.
10. Block it in when parked. Towing is your greatest risk. A cheapo solid draw/tow bar is the normal MO. They'll even drag them if needed. Lifting also a risk, but minimal IMHO.
11. Tracker. Either go the full monty and get a posh one, or do the diy iphone 'find friends' version. Cheapo Chinese trackers also work well. The issue with the radio/UHF/VHF trackers is they are often put in a handful of places, and there are tell-tale signs that give them away. Blocking of all trackers also a problem, with cheapo jammers available on ebay. So be aware of that risk.
12. If a 110, cut off the rear door lock latch knob. The small knob on the lock, so the door can't be unlocked from the inside if someone pops in the small rear windows.
13. Those small rear windows on a 110 are a risk. Be aware they can be popped out easily, but various fixes are available.
14. Protect the bonnet pull cable with a guard above the rad, and liquid metal or rivet down the screws on the wing top blanking plate on the drivers side to protect the cable under there too.
15. Bike lock cable and padlock your spare wheel to the carrier on the rear door.
16. Security mark everything, windows, panels, wheels, seats. the lot. Use VIN or VRM as an etch.
Lastly. Be aware that ALL of the solutions available have a work-around or weakness when used in isolation and the villains know them too. Don't fall for the vendors marketing guff, understand the workaround and seek to mitigate it. Add 2 or 3 different solutions if you can, but don't make your life hell when you come to use the vehicle or you'll end up not doing them at all and it's all for nowt.
Also.. understand your local risk. Do you live in a high risk area like Yorkshire, or somewhere more sedate. Ask the local plod about vehicle/rural crime to get some idea of what the risk is and how vehicles are stolen. Likely to be crime gangs using the same methods each time.
Post #746288 18th Dec 2018 12:27pm
