Home > Maintenance & Modifications > Bearmach Puma style worklight switch
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Has anyone used one of these yet?
https://bearmach.com/switch-assembly-rear-lamp-ba-10306
The wiring diagram that comes with it shows two totally different switch inards and all I seem to be making at the moment is a big pile of blown fuses
Simply want to use it as an on / off switch with dash illumination.
Post #743194 30th Nov 2018 2:55pm
drinkdrinkdrop
assuming the body is the old YUG000540LNF (normally with the light with a 2 in the middle facia) wire as follows
Switch
1 to relay 85
2 to orange/red dash illumination circuit (find a spare one on a switch you're not using or splice into the circuit elsewhere)
3 blank
4 to ground
5 to relay 87 (this provides the tell tale light)
Relay
30 Fused positive from the battery you also want a short wire between 30 and 86 so when adding your blade connector crimp in an extra short wire
86 from 30
87 to light and switch pin 5
85 to switch pin 1
Light
+ from 87
- to ground
Post #743204 30th Nov 2018 3:53pm
Al_The_Pal
Brilliant thanks, it was the return wire for the tell tale light that threw me, I thought this was handled inside the switch body, I have run a signal wire back from the relay and all makes sense now,
Post #743222 30th Nov 2018 5:15pm
PaulMc
I see that Bearmach have nicked my diagrams Shocked
The top one is the one I did for YUG000540LNF
The bottom one has been slightly modified from the one I did for replacing the expensive and unreliable control unit in the D2 auxiliary lights wiring kit, with a relay and Puma heated seat switch with the D2's binnacle switch cap on it -
. Paul.
Post #743253 30th Nov 2018 7:01pm
reverendalc
United States
thread resurrection
soo.. sorry to join a forum and immediately resurrect a two year old thread... but i'm having a heck of a time making sense of this bearmach diagram myself. i've built my plugs following schematic #2 on the sheet and i've got my relays wired (i'm rigging four floods on the roof, two floods on the ARB, and a work lamp off the back.
my brain has broken in approximately the same stage as the OP, though I haven't hooked up to power yet. i have a firm grasp of 12v electronics, but the diagram is confusing, as it seems to indicate that PIN3 is internally linked to PIN4 in the top diagram and PIN5 on the bottom diagram.
i have tested the tines with my DMM, and i have continuity between PIN3 & PIN4, and not PIN3 & PIN5. that stinks because i've wired according to diagram 2 as i'd like to have their operability contingent upon my headlamps being on, and i've used colored primary wire according to all of my custom wiring and i've soldered the plugs together already.
adding confusion to confusion, both of the switch illustrations do not match.
i could easily follow drinkdrinkdrop's succinct instructions, swapping R30->R86 with tapping headlamp circuit->R86, but i really really really want to know what the heck this paper is talking about.
thanks in advance
Post #824509 11th Apr 2020 4:56am
Unfortunately, Bearmach's instrructions are a bit of a mess. Only diagram 1 is correct for the switch that you have and connections can be made as described by drinkdrinkdrop above, but this will give you independantly switched lights.
If you follow the diagram then this will give you lights that only work when the main beam in on.
Diagram 2 is for a completely different version of the switch, I'm afraid. Darren
Post #824539 11th Apr 2020 8:36am
reverendalc
United States
Diagram 2 being for a different switch explains some things... except why TF they send it out.
Thanks for clearing that up. I suppose I’m just going to have to deal with mismatched wiring.
Post #824600 11th Apr 2020 3:01pm
jst
glad i found this, explains why i couldn't get the switch working earlier! good old forum! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #889085 4th Mar 2021 8:04pm
