![]() | Home > Wheels & Tyres > ET0 Offset Rim as a Spare? |
If you run ET0 rims should you match the spare wheel with same offset?
![]() I'm just thinking maybe the standard off-set would be better for the spare (whether it be on the rear door or bonnet) to keep it closer to the body, less stress? But is it OK to temporarily run a standard offset rim when the rest are ET0? TIA ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
The advantage to having a non matching spare is that it forces you to get the punctured tyre sorted (instead of not getting that done next week
![]() I'd imagine though that it would be horrible to drive if it were on the front. I have an 18" ET10 on my back door with no ill effects ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 524 ![]() |
Yes I have done this - no worse than a space saver as long as the diameter of the tyre is the same
